Bridge output RMS POWER 10000WX1CH car amplifier www.gedunaudio.com
http://www.gedunaudi...w/01/18003.html
XP-10000.1
Class-D mono (Digital) car amplifier
Super-efficient Class-D PWM design runs much cooler
High-efficiency MOSFET power supply
Platinum Plated Heavy Duty Power & Speaker Terminals
Two Amp Linkable Function:
Output Master And Input Slave (yes)
Short circuit / thermal / overload / DC offset protection
Wired Remote Controller
There are two groups of signals convert RCA output
Soft delayed remote turn-on / off circuitry
Fully 1Ω stable operation (Mono only)
Subsonic filter (Mono only)
Variable phase shift (Mono only)
Heavy-duty heatsink
Oversized capacitor tanks
Adjustable low gain control
Power / Protect LED indicators
Model:XP-10000.1
Type Class-D Mono Car amplifier
RMS Power Ratings
1CH 1ohm 10000 Watt
1CH 2ohm 5000 Watt
1CH 4ohm 2500 Watt
T.H.D Tested Voltage & THD : 14.4V & Less Than 1% THD
Signal to Noise > 90db
High-Pass
Low-Pass 25Hz~250Hz
Damping Factor +350
Bass Boost 0 ~ 6 dB
Variable Phase Shift 0 ~ 180 degrees
Double Sided Through Hole Epoxy PCB FR 4 PCB
Input Sensitivity 200mv~6v
Fuses Rating 20A*4 NO!
Dimension (M M) Length (850 mm) * width (260 mm) * height (55 mm)
weight: Net Weight( 16 kg)Gross weight ( 18 kg)
XP-10000.1
Spam much?
EAST TEXAS BASS HEAD 4 LIFE
Jeep electronics = Stock (for now)
Headunit = VR3 cheapo
Speakers = Pioneer and Quantum Audio
Sub Amp = Sundown SAE-1200d
Sub = Fi SSD 15''
Mid/High amp = Sold my 4ch, Lookin for a new one now....
REFS: Bought From-Twistedchild420 ,J_black10,SojiaRaggs9000,hotshot27,
REFS: Sold To- James , sanitarium , qu1cks1lver56, skittlesRgood
Offical Audiogod9000 Feedback
Audiogod9000's 1997 Jeep Cherokee Country Build
