I have 2 10w3v3 from JL Audio.
A few weeks back i determined that my box was a wreck on the inside. It was a older box and only about .75 cubes per woofer once i did measuring on it.
Can anyone suggest some dimensions or send me a schematic of a good box design for these woofers?
I have a truck so i can make the box as big as it needs to be, I just want it done right this time so let me know what size the box needs to be.
Thanks in advance for any help given.
are you wanting you renclosure to be ported or sealed and what do the sub spec sheet say they need for wither one??
The spec sheets for the sub is as follows.
Free Air Resonance (Fs): 31.49 Hz
Electrical “Q” (Qes): 0.523
Mechanical “Q” (Qms): 7.017
Total Speaker “Q” (Qts): 0.485
Equivalent Compliance (Vas): 1.138 cu. ft. / 32.23 liters
One-Way, Linear Excursion (Xmax)*: 0.550 in. / 14.0 mm
Reference Efficiency (no): 0.185%
Efficiency (1W/1m)**: SPL 84.87 dB SPL
Effective Piston Area (Sd): 53.475 sq. in. / 0.0345 sq. m.
DC Resistance (Re): 3.567 ohm
Nominal Impedance (Znom): 4 ohm
Thermal Power Handling (Pt): 500W
Driver Displacement: 0.049 cu. ft. / 1.39 liters
Net Weight: 12.25 lbs. / 5.56 kg
I would really like a box that is ported this time around. I've had the sealed box(although not a very good one) with these speakers so i would like to hear what they can really pump out with a ported box.
  • Who's Online   0 Members, 0 Anonymous, 1237 Guests (See full list)
