which one of these batteries is better for a 2400 watt system? i have an alt 125 amp, stock battery up front and will be using the other as secondary. my budget is under 200 final price. is there anything out there better than these two batts for that price?
http://www.sonicelectronix.com/item_17904_SHURiKEN+SK-BT80.html
http://www.sonicelectronix.com/item_10462_Kinetik+HC1800+-Special+Application+Version-.html
i would
alright thanx a lot! one other quick question to wire the battery is it ok to go with this type of cable?
http://www.knukonceptz.com/productDetail.cfm?prodID=KLMX0BL
and two fuse fuse holders one on each side coming from the batt 12" away and the other side 12" as well with a 250amp fuse on each will it be fine.
Are you talking about connecting the front battery to the back battery? If so yes, do it like so
"Front Battery ------ Fuse ------------------------------------- Fuse ------- Rear Battery"
With 1/0 cable, I would just go ahead and use a 300A fuse, but a 250A fuse will work perfectly fine. And yes that wire will work fine.
Edited by kl0wn
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
yeah that's what i meant sorry. thanx!
  • Who's Online   0 Members, 0 Anonymous, 838 Guests (See full list)
