Are you talking about connecting the front battery to the back battery? If so yes, do it like so
"Front Battery ------ Fuse ------------------------------------- Fuse ------- Rear Battery"
With 1/0 cable, I would just go ahead and use a 300A fuse, but a 250A fuse will work perfectly fine. And yes that wire will work fine.
oh and to wire up the amp to the battery do i use another fuse holder and amp fuse the same size?
What size wire will you be running from the second battery to the amp? The fuse size depends on how big the wire is, if you are using more 1/0 just go ahead and put a 300/250A fuse in and call it a day.
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
yup 1/0 gauge. thanx a lot bro i appreciate your help.
Why should there have two fuses installed on the same cabling run from the POS of the main battery and the POS of the aux. battery? Aren't the fuses to protect the wiring? Please explain....later
this might help. check it out.
yes thats a good informational video
2 Fi BTL N2 18s Fully LoadedSundown Audio NS-1Kenwood 845 HU Clarion EQ4 Juicebox 3100sKnu Wire"Big 3"Mechman 270a156.3dBTeam GG.
  • Who's Online   0 Members, 0 Anonymous, 755 Guests (See full list)
