What's your budget/electrical consist of?
My POS Bass machine-
2003 Hyundai Santa Fe on some shitty 22's
Bed Liner Paint Job-Pioneer AVH 3200DVD
4 DAD BD series 15's in a 4th Order (Bassheads ENT Design)
4 Arc Audio XDI2000.1 for the woofers
6 Cadence CVL68MBX 6.5's-Cadence CVL88MBX 8's-6 Cadence XT20 Supertweeters
2 Arc Audio KS300.4's for mids and tweets
1 Arc Audio ALD 10v Line Driver
All Audiotechnix Power wire
1 DC Power 270XP High Output Alternator
1 XS Power D3400 up front....6 XS Power D3100's in the rear
Air Lift 1000 Bags in rear to help with suspension
If your still reading this GFY.......
My best friend is using two hifonicw 2610D strapped to a pair of BL´s 15" , we clamped 3800 watts and they handle the power just great, we actually did 70 demos in one night and they behaved great, i guess the BL 18" can handle more than 2K without a problem.
Bridge output RMS POWER 10000WX1CH car amplifier www.gedunaudio.com
http://www.gedunaudi...w/01/18003.html
XP-10000.1
Class-D mono (Digital) car amplifier
Super-efficient Class-D PWM design runs much cooler
High-efficiency MOSFET power supply
Platinum Plated Heavy Duty Power & Speaker Terminals
Two Amp Linkable Function:
Output Master And Input Slave (yes)
Short circuit / thermal / overload / DC offset protection
Wired Remote Controller
There are two groups of signals convert RCA output
Soft delayed remote turn-on / off circuitry
Fully 1Ω stable operation (Mono only)
Subsonic filter (Mono only)
Variable phase shift (Mono only)
Heavy-duty heatsink
Oversized capacitor tanks
Adjustable low gain control
Power / Protect LED indicators
Model:XP-10000.1
Type Class-D Mono Car amplifier
RMS Power Ratings
1CH 1ohm 10000 Watt
1CH 2ohm 5000 Watt
1CH 4ohm 2500 Watt
T.H.D Tested Voltage & THD : 14.4V & Less Than 1% THD
Signal to Noise > 90db
High-Pass
Low-Pass 25Hz~250Hz
Damping Factor +350
Bass Boost 0 ~ 6 dB
Variable Phase Shift 0 ~ 180 degrees
Double Sided Through Hole Epoxy PCB FR 4 PCB
Input Sensitivity 200mv~6v
Fuses Rating 20A*4 NO!
Dimension (M M) Length (850 mm) * width (260 mm) * height (55 mm)
weight: Net Weight( 16 kg)Gross weight ( 18 kg)
  • Who's Online   0 Members, 0 Anonymous, 479 Guests (See full list)
