manofthehour Posted April 17, 2010 Report Posted April 17, 2010 Ok so I have a couple PC fans I am wiring up to my car to keep the amp cooler. They are just DC 12V 0.10A powered. I was going to hook them up to a cig lighter so it turns off and on with the car. The question I have is do I need another fuse or will the fuse that is used by the cig lighter cover it? My stuff '06 Scion xA: -Alpine iDa-x100 -Alpine KTP-445 Power Pack -Polk Audio db6501 (front components) -Polk Audio db651 (back coaxials) -2 RE Audio SEX12D4s -Cadence F1200-1D - Custom box tuned to 33Hz - Kinetik HC1400 - 50 ft2 of Audio Technix sound deadner - Big 3 My photography page
bcpballer64 Posted April 17, 2010 Report Posted April 17, 2010 You can prolly just power them off of the remote wire or the 12v into your amp. "The strongest reason for people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government." -- (Thomas Jefferson)
manofthehour Posted April 17, 2010 Author Report Posted April 17, 2010 You can prolly just power them off of the remote wire or the 12v into your amp. oooo even better lol thanks! so ur sayin just stick it in with the wire that comes from the battery and the ground to the ground from the amp or are you saying that the remote turn on wire will power this thing? My stuff '06 Scion xA: -Alpine iDa-x100 -Alpine KTP-445 Power Pack -Polk Audio db6501 (front components) -Polk Audio db651 (back coaxials) -2 RE Audio SEX12D4s -Cadence F1200-1D - Custom box tuned to 33Hz - Kinetik HC1400 - 50 ft2 of Audio Technix sound deadner - Big 3 My photography page
bcpballer64 Posted April 17, 2010 Report Posted April 17, 2010 the remote turn on might nvm bought puttin it in with the 12v that would make them run all of the time. but ya try the remote part. put the positiv of the fan in with the remote and the negative of the fan in with the ground. "The strongest reason for people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government." -- (Thomas Jefferson)
manofthehour Posted April 17, 2010 Author Report Posted April 17, 2010 the remote turn on might nvm bought puttin it in with the 12v that would make them run all of the time. but ya try the remote part. put the positiv of the fan in with the remote and the negative of the fan in with the ground. alright ill try it out now thanks! My stuff '06 Scion xA: -Alpine iDa-x100 -Alpine KTP-445 Power Pack -Polk Audio db6501 (front components) -Polk Audio db651 (back coaxials) -2 RE Audio SEX12D4s -Cadence F1200-1D - Custom box tuned to 33Hz - Kinetik HC1400 - 50 ft2 of Audio Technix sound deadner - Big 3 My photography page
manofthehour Posted April 17, 2010 Author Report Posted April 17, 2010 Works great! not a lot of airflow so I'm gonna get some 120mm fans. My stuff '06 Scion xA: -Alpine iDa-x100 -Alpine KTP-445 Power Pack -Polk Audio db6501 (front components) -Polk Audio db651 (back coaxials) -2 RE Audio SEX12D4s -Cadence F1200-1D - Custom box tuned to 33Hz - Kinetik HC1400 - 50 ft2 of Audio Technix sound deadner - Big 3 My photography page
