Guest Posted April 17, 2010 Report Posted April 17, 2010 So im planning on buying another level 3 (run 2) and the site says 1.5cuft for ported and 2cuft for "SPL". which one should i go for? planning on giving them 600, maybe 700 a piece. edit: also i was thinking about doing a 35hz tuning, nothing too drastic since i'd want a somewhat balanced response.
hdorre Posted April 20, 2010 Report Posted April 20, 2010 So im planning on buying another level 3 (run 2) and the site says 1.5cuft for ported and 2cuft for "SPL". which one should i go for? planning on giving them 600, maybe 700 a piece. edit: also i was thinking about doing a 35hz tuning, nothing too drastic since i'd want a somewhat balanced response. SPL boxes are clearly bigger. As a result, they gain efficiency. You said youre giving them 600-700 watts each which is their rated RMS. I would do the SPL enclosure. If you went the minimum enclosure size, you'd probably need more power On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
JPagan Posted April 20, 2010 Report Posted April 20, 2010 SPL boxes are clearly bigger. As a result, they gain efficiency. You said youre giving them 600-700 watts each which is their rated RMS. I would do the SPL enclosure. If you went the minimum enclosure size, you'd probably need more power Do 3 cubes net for the pair. this is a pair of lvl 3s in 3 cubes on a newer version of your amp...
