steven Posted April 18, 2010 Author Report Share Posted April 18, 2010 Where is your ground at. The rear strut... I have had 2 systems in this car with the same set up and I have been running the 10s in here for almost 2 weeks then it just started doing this last night when I doing some testing. Then continued to do it today. Quote Link to comment Share on other sites More sharing options...
big dee Posted April 19, 2010 Report Share Posted April 19, 2010 (edited) try replacing your rca cables i had samething happen and that was my problem or could be bad sub maybe Edited April 19, 2010 by big dee Quote Link to comment Share on other sites More sharing options...
steven Posted April 19, 2010 Author Report Share Posted April 19, 2010 I just switched my amps and put in my other 3500s im going to up load a vid right now Quote Link to comment Share on other sites More sharing options...
EclipseChris Posted April 19, 2010 Report Share Posted April 19, 2010 One time i had my amps go into protect mode because the speaker wires got tugged and grounded to the body (not my sub wires) so my advice is take the speaker wires out from the amp (after you label them if it helps) and see if it still goes into protect, if it does not it is the speaker wires. Quote i resolve to be a nicer moderator. Tercel build R.I.P. Eclipse build Old New V-Dub My feedback. Link to comment Share on other sites More sharing options...
steven Posted April 19, 2010 Author Report Share Posted April 19, 2010 Found the problem the ground wire on the head unit had been was yanked kinda loose exposing the wiring and coming into contact with the remote wire during driving thanks for all the help though guys... Quote Link to comment Share on other sites More sharing options...
