ok on both my ap 3000's the screw down terminals for the speaker wires are stripped, i have a nasty habbit of over tightening them and yea thats what happened..is there any way to fix this? bigger screws? a dab of hot glue? just wanna ensure the wire wont pop out
My F-150 Build
GET ON THE BANDWAGON
what if they tried messing with the amps when the subs werent louder :ehh: hahah jk :pardon:
what i do when screws go to shit is just strip some wire back about 2'' or so and run it threw the screw hole and back out the bottom and twist it on itself and then solder it and wa la, but i dnt kno what you can do with 8guage or so speaker wire
they make a rethreading meterial for machine parts but theres not that many thread rows on an amps screws
if its a set screw i dunno what to do but if its one of those type screws that have a flat piece on top to hold down the wire u could prolly run a smaller bolt down threw it and put a nut on the end and then u can wrench the fuk out of it lol
here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp
here's a link to my other system my 90 geo prizm test car
heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
if this is your amp
if its hella stripped i would just drill a hole down threw the bottom part and just run a bolt threw it and put a ring terminal on the speaker wire, should work i would think since there just lil boxs wit a hole in one side and set screw on top
i guess if all else fails i can just solder it in there, will be messy but i know it will stay, i dont really see any way of re threading it because of the size, i guess i could try a bigger screw but dont wanna break anything...not to self, dont over tighten next time lol
My F-150 Build
but befor doing anything, if u have enough room to rethread i would rethread it to another bolt pattern
i think u drill it out and thread it but i think u can still rethread a threaded hole, i would try a rethread first, and if that dont work try the other option, thats bout all i can think of bro
i hate stripped set screws, and phillips set screws, ied rather have an alan head screw than anything
idk if thats my amp or not, ive never opened it up lol..im sure i could do the bolt thing if it gets worse, i can get the wire in and make it stay due to the size, so i may just put some hot glue thats easy to take off around the edge of the terminal so it wont move
My F-150 Build
get a tap and die set. if its too bad youll have to cut new treads in the mounts and get new screws
this would be more of a long term fix
Edited by DirtyD78
2003 CHEVY SILVERADO REG CAB
H/U SONY W/ IPOD TOUCH
new build
2 dc audio lvl4 xl's
rd audio 3250
box is behind the seats
below the window
3.44 after tuned@34 htz
147.3@44 htz & getting louder
if u get some titanium drill bits i think u might can just bore all the way threw the top were the screw goes threw and put a nut on bottom and ring terminal on speaker wires, should work, i would do it if my speaker outputs wasnt at an angle
and since u got 2 sets of screws are they all stripped or just 2 of em? ied try another route if i could
There is also a rethreading kit, I believe they are called tapcon rethreading kit. They are made to put new threads into stripped out metal, They use a hardened steal thread insert, that basically you tap it into the new area and it has the same internal thread as the original screw hole. It is really hard to strip those once you insert them. Good way to go IMHO
link please?
and yes the screw holes are stripped on the "bridged" portion of the amp the two far inputs
My F-150 Build
