Thanks for ur time mate,
ive just started out in this car audio so i dnt no my stuff + im only young
Im not sure what you mean by displacement ?? i brought boxes from sum1 who said it was an spl set up in his car but they got no port length so i want to add a port length for better sound ???
Tell me what info you need and ill tell you my friend
i'll try explain, displacment is when you put ur sub in the box, how much air space is left, basically the dimentions of your sub. You could get this info by finding the specs of your subs online, and that would help.. :D
Posted (edited)
This is all the info i got on the subs also a pic !!!!
I got 8 for £150 gbp so about $250-300,Im on a budget otherwise i would of brought Re or suming like that but im skint LOL
Another thing could i invert the front 2 on each box to get air space back or making the slot port come out or does it not work like that ???
Need help with the wiring tho....
Heres the stats,On the box in the pic it says 12'' but these are the 15'' i just cant find a pic for the 15''s but got the info below !!!
Dual 2.5" aluminium voice coil
Large foam surrounds
Chromed aluminium baskets
1000w max (500w rms)
Freq resp 25-4000hz
Imp 2-4 ohms
Tell me what more i need to tell you
Thanks again
Edited by 8x15inagolf
Posted (edited)
What do you reckon then ???
I dnt want to build new boxes cos ive got these,can i mod them a little in sum way,My car is small but im going to do it sum how,Please dnt turn me off the whole car audio thing : (
What would air space be like if like i said inverted the 2 at the front on each box
Haha I don't want to "turn you off" but there is no way youll fit 8 15's in a gold without maddddd fiberglass work. I'd drop it down to 4 15's and build a wall for them. Walls are very badass, and I would love to build one if I had the cash for more amps and subs.
A couple links to some box builds:
Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI,
Mini-Bump, Hummer H2, Ford F-150
My own car builds (current setup --- under construction):
Overall Thread, Kickpods, Dash, Back Doors
Subwoofer Wall
lol...
you wont find anyone who thinks that 1.5 cubic foot is good for a 15.
I don't care how nicely they fit in the car, if the subs don't work in the box youre screwed anyway. What you can do is make the boxes sealed, and not use a port at all. You'd get extra displacement back, and 8 15's in a golf, even sealed, would be very loud. Just make sure you seal the boxes off from the back of the car.
Subwoofer Wall
