Help people,im in the uk and in need of help
Just brought 2 boxes that fit together to form a V-shape behind drivers seat in my mk2 vw golf/rabbit
there like 2 wedge boxes that hold 4x15 each both have 2 slot ports which are about 14x2 but i need a port length HELPPPPPPP
my setup so far is :
8 x 15's 2ohm Dvc woofers 500rms each
2 red top optima batterys in back
1guage wire through out
audio control 150
not sure what amps yet mayb hifonics but im on a budget
Looking for around 32 HTZ !!!!!!
as for the boxes there about 35 x 35 x 17 x 9 each in a wedge type box 3/4'' mdf,will get pics but i cant work out my port length ( 2 slot ports per box measuring 14x2 each
How much more info you need ???
Thanks for your time
Edited by 8x15inagolf
2- pre fab 4-15" boxes? something like that, I think it would have been best to custom build in the car. The airspace seems somewhat adequate, any way you can do a sketch in paint to show how it will be set up so we know hot its going in? cuz ports you may want to fire straight fwd
dont know what kind of woofers you got, but you said DVC, thinking its Dayton DVC, the port could be about 6"x6" x9.75" long... if you have a different sub, let us know
dohh 32hz, not 34hz....
6"x6"x12"
where abouts from UK are you mate?
Also as mentioned above is airspace going to be enough? im sorry i cant help with the port length still trying to learn that process....
Give it some time i reckon you'll get an answer sooner or later ;)
each box is sectioned off so 2 15''s per slot port altogether 8 15''s 4 slot ports sum1 must be able to guide me i just cant work out those calulators !!!!
thats the only fing stopping me from making loads of flex vids !!!!
