and wow the shaking and and the bass is so much more agressive. pulling the air from my lungs and it pounds much harder now. it pounds my chest and i still have yet to fully crank it. its weird the lows dont draw as much power as the high bass its REALLY weird. i do notice a LITTLE SQ loss not much AT ALL though. but it it agressivly loud and its puttin on a hurtin. i think i could hit at least a 144.
my suggestion for anyone who gets 2 T1s and a T10001bd. UPGRADE your elcetrical system. if your not going to then stick with dual 2s...they will sound good. and BRACE yourself for one hell of a ride. these suckers are LOUD!!! TY RF :^
NoFearX18 said:
trainman0978 said:
SWEET.... can't waite for you to turn it up all of the way, and do a vid. or too :^
SMDsigbannr4.jpg1995 Geo Prism . FI BTL 12 P chamfer, 3rdmagnet HIXMAX COIL 1/0 big 3 HIFONICS COLOSSUS 1.7 cubs tuned to 60hz in the works 2xTruck battery 1125 cca.
will do once they are broken in :D
NoFearX18 said:
trainman0978 said:
with two dual 4 ohm subs you can wire them down to a 1 ohm load at the amp = more power
with two dual 2 ohm subs it's either 2 ohm (less power from amp) or .5 ohm  (which will send his amp into protect or blow it
sorry for the noob questions but why does it make a difference if its 2 ohm or 4 ohm? and you think you could do a hair trick with those 12s?
AP explains it...and i think i can get a little hair trick going...i will try it and if i can do it  i will post a vid of it
NoFearX18 said:
trainman0978 said:
let me know i can help you out with that amp accessories and what ohm load sub...you will be VERY happy with the SQ and how loud this thing gets :D
NoFearX18 said:
trainman0978 said:
  • Who's Online   0 Members, 0 Anonymous, 900 Guests (See full list)
