808head Posted April 21, 2010 Author Report Posted April 21, 2010 Correct unless your running multiple amps then you use a relay. Should work, Just that the top image will only turn your amp off if you turn the the switch off. And the 2nd one will turn the amp off if you forget to flick the switch and will turn it off by the ignition switch so when you take the key out of your car. 92 Black Acura Vigor (Blacura) pioneer head unit powerbass s-series 6 1/2 components in front 2 stock tweets up on the dash 2 stock 1 inch speakers by the front dome light alpine spg-17c2 6/12s in the back,custom fiberglass pods for them hifonics MX-3 sound processor/line driver BIG 3 done stock alt...not for long 1/0G all around optima yellowtop up front kinetik 2400 in the back Powerbass XA3000d sub amp 2 MTX 9500 12s, single 4 ohm vc (so only doing about 2200w) 8awg wire for the subs
808head Posted April 21, 2010 Author Report Posted April 21, 2010 thanks everyone i got some options now..i dont know what i would do without SMD..ill put some pictures up of the switch when im all finished it should look cleeeaan as hell 92 Black Acura Vigor (Blacura) pioneer head unit powerbass s-series 6 1/2 components in front 2 stock tweets up on the dash 2 stock 1 inch speakers by the front dome light alpine spg-17c2 6/12s in the back,custom fiberglass pods for them hifonics MX-3 sound processor/line driver BIG 3 done stock alt...not for long 1/0G all around optima yellowtop up front kinetik 2400 in the back Powerbass XA3000d sub amp 2 MTX 9500 12s, single 4 ohm vc (so only doing about 2200w) 8awg wire for the subs
David78 Posted April 21, 2010 Report Posted April 21, 2010 I have a dumb question, is it necessary to run a switch? ...............................____ ...............__________|___\____ ..;.;;.:;:;.,;.|__(O)____|____/_(O) 1978 F-150 Ranger Lariat 2 Sets of Sound-stream Components Sony Head-unit DDM Tuning 8000k's Euro Headlights (Projectors Soon) Green Led Wheel Wells Dark Red Tails Tint
808head Posted April 21, 2010 Author Report Posted April 21, 2010 I have a dumb question, is it necessary to run a switch? not in my case because i only have one amp..but like i said before im doing it for show/looks because its got the LED in it..but if you have multiple amps it is nessessary 92 Black Acura Vigor (Blacura) pioneer head unit powerbass s-series 6 1/2 components in front 2 stock tweets up on the dash 2 stock 1 inch speakers by the front dome light alpine spg-17c2 6/12s in the back,custom fiberglass pods for them hifonics MX-3 sound processor/line driver BIG 3 done stock alt...not for long 1/0G all around optima yellowtop up front kinetik 2400 in the back Powerbass XA3000d sub amp 2 MTX 9500 12s, single 4 ohm vc (so only doing about 2200w) 8awg wire for the subs
mikeg321 Posted April 21, 2010 Report Posted April 21, 2010 If you run the switch from the battery put a fuse on the wire as close to the battery as possible! 4 fully loaded Fi sp4 15's 2 Crescendo bc5500s Crescendo c1100.4 6 focal mids Vifa tweets 5 XS Power d3100's Pioneer avh-p4200dvd All crammed into a mustang. http://www.stevemeadedesigns.com/board/topic/150569-mikeg321s-fi-nendo-mustang-getting-walled-videos-page-4/
Guest Posted April 22, 2010 Report Posted April 22, 2010 not in my case because i only have one amp..but like i said before im doing it for show/looks because its got the LED in it..but if you have multiple amps it is nessessary no its not. MANY people on here use relay's to turn multiple accessories on. its simple and you wont forget to turn it off when you shut the car off since it shuts off when the remote source (headunit) is gone.
