Decaf Posted April 22, 2010 Report Posted April 22, 2010 how are ur bats? what kind... resting voltage? Quote
aleroking Posted April 22, 2010 Author Report Posted April 22, 2010 not to sure just had to put my friends bat in there. resting mid 12's though O yeah also my friend has the same car and got the same alt made, and he was dropping to mid 12's with only like 100 amps being drawn and yellow optima upfront Quote 2 fi btl 18s on 2 crescendo 3500s walled in a 2dr 2000 alero build log http://www.stevemeadedesigns.com/board/topic/141663-2-walled-btls-18-on-7k-in-a-2000-2dr-alero/
Decaf Posted April 22, 2010 Report Posted April 22, 2010 (edited) resting should be 12.8-13.3 do u just have 1 stock wet cell...? replaced it with dry cell...? rear batts...?????? try charging the batt(s) overnight so the alt isnt trying to recharge the batt(s) and supply the amps Edited April 22, 2010 by Decaf Quote
aleroking Posted April 22, 2010 Author Report Posted April 22, 2010 resting should be 12.8-13.3 do u just have 1 stock wet cell...? replaced it with dry cell...? rear batts...?????? try charging the batt(s) overnight so the alt isnt trying to recharge the batt(s) and supply the amps yeh just one stock wet cell, but if you read about my friend ( if he has a 200+ amp alt, drycell up front and only 100 amp draw he shouldnt be dropping into the low 12's? Quote 2 fi btl 18s on 2 crescendo 3500s walled in a 2dr 2000 alero build log http://www.stevemeadedesigns.com/board/topic/141663-2-walled-btls-18-on-7k-in-a-2000-2dr-alero/
dugee81 Posted April 24, 2010 Report Posted April 24, 2010 Cheap alt, u get what u pay for man. You cant expect the same quality to go into a $100 investment as opposed to a $400 one. Quote 200a alt. by Excessive Amperage hc800 under hood & 2 Deka 9a31 in rear 1/0awg + big 3 SAZ 3000D HDC3 18" @ 2 ohm
aleroking Posted April 24, 2010 Author Report Posted April 24, 2010 my friend went up there they just changed his regulator to 15 volts the guy did a load test in front of him with a 250 amp load the alt voltage wasnt dropping at all Where going up there today because the guy is talking about some computer in the car could be holding the alternator back or something. Quote 2 fi btl 18s on 2 crescendo 3500s walled in a 2dr 2000 alero build log http://www.stevemeadedesigns.com/board/topic/141663-2-walled-btls-18-on-7k-in-a-2000-2dr-alero/
InfiniteRuckus Posted May 5, 2010 Report Posted May 5, 2010 my friend went up there they just changed his regulator to 15 volts the guy did a load test in front of him with a 250 amp load the alt voltage wasnt dropping at all Where going up there today because the guy is talking about some computer in the car could be holding the alternator back or something. I'm curious how this worked out 4 ya Quote
