Wish I got that lucky, I mean its still loud . But with the trunk open its x2 louder..
Vehicle: 2008 Chevy Cobalt LT
Exterior: Tinted tails, Lowered with Eibach Springs, Black Housing Headlights, 6000k HIDs
Amplifiers: Rockford Fosgate P400-4 & T10001bd
Batteries: Kinetik HC1400
Electrical: Big 3 Stock Alt
Enclosure: 4 ft³ @ 33Hz 75sq.in. of port (18.75sq.in. per cube)
Headunit: Pioneer AVH-P4100DVD w/ 80G iPod
Mids/Highs: Boston Acoustics SL60 (front), Boston Acoustic SX95 (rear)
Subwoofers: 1 15" Fi BL Fully Loaded
Wire: 1/0g KnuKonceptz Kollosus, 4g MobileSpec
damn! that sucks balls I wish I had an answer for this one. hey its looks good :pardon:
06 chrysler 300C Hemi
one mmatts dreadnaut 15 powered by a planet audio vx 2200d
fosgate p200 running planet audio 8" midbass drivers and super compression tweeters
stock battery and a stinger spv44
Irragi 300 amp alternator
big 3 1/0
http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1
Thanks :good:
Roll around with the trunk open :) j/p, good luck with this.
2001 Bravada (2wd) Pewter on 24's
JVC KW-AV60BT
10 Alpine Type-S 6.5s
2 PSI/BTL 18's @ 32Hz
2 Rockford Fosgate T25001-bd's @ 1-ohm each
Rockford Fosgate T1000-4
Rockford Fosgate T400-4
Rockford 3Sixty.2
Yellow top up front, 2 9a31s in the back
LOTS of AT 1/0
Python 991
350 Amp Singer Alt
"Build Log"
My Facebook
My YouTube
i didnt see the video or read anything but...cool story
and the reason your being a cock tonight is?
seal the rear deck
R.I.P!
(Nov-29-2009)
92 explorer
current build
Lol ive thought about this.. who needs a trunk lid anyway? good luck to whoever tries and steal this box outta my trunk lol
I have an idea your not gonna like it cause your goin to have to tear out the foam and the pannels but do that and then make new ones put them in place and dynamat around the whole thing top to bottom overlapping the box and the sheet mettal of car then refoam it here is a pict of mine
big 3 1/0
I did something similar maybe it might help you as well. Anyways what I did was, I made a surround of sorts. Basically it fits snug into the curves of trunk wall. Then I added an other piece to act as a separator. which gave me a flat surface to attach to my box. I put expanding foam in front of this piece where it touch the frame. I then Put my box in and added more foam to seal up where the box and wall meet. I still need to seal off the package tray area but its defiantly better than it was before. Plus this way you can Have the seats up if you got passengers and pull em down if you dont. :P
http://www.stevemeadedesigns.com/board/topic/71075-sojiaraggs9000s-final-box-build/
* Eclipse CD3200 with PAC SWI-CAN2 and SW-ECL2 Steering Wheel Controls Interface
* Pioneer D-Series Mids and Highs ( Fronts: TS-D1702C; Rears; TS-D1702R and Dash; TS-D1002R )
* Rockford Fosgate PBR300X4 ( Mids and Highs Amp )
* DC 3.5k with Dual Inputs; Custom Plexiglass Backing ( Sub Amp )
* Rockford Fosgate Balanced Line Driver
* One FULLY LOADED ~ 10" DC m2 XL
* Custom Built Carpeted Ported Box Tuned to 32hz. Single Chamber With Volume of 1.44618³ ft ; 1.13216³ ft After Displacement
* Custom Built Carpeted Trunk Wall with Added Fans for Amplifier Cooling
* MechMan 240a High Output Alternator
* KnuKonceptz Krystal Kable RCA Cables
* Upgraded Electrical With 1/0 KnuKonceptz Kolossus Fleks Kable and 1/0 Sky High Car Audio Cable
* Five Exide Orbital ORB34M Marine 12 Volt Batteries
* PowerMaster XS D3100 12 Volt Battery
My 2008 Chrysler 300 Limited - SuperCharged 3.5L V6 - UBL
My Old 2005 Ford Taurus - CarDomain - Vehicle Was Sold
I did almost the same thing, it still slams with the seats up too
¿ǝɯɐƃ ǝɥʇ
yeah my seats can fold up if I have passengers or if I'm by my self or just another passenger I leave em down
big 3 1/0
