byers319 Posted April 26, 2010 Report Posted April 26, 2010 alright so i have a dual 4 ohm 15" alpine r series hooked up to a 1800 watt kenwood amp its hooked up to two ohms the sub is slightly underpowered if factory specs are correct what amp should i be running with this sub? or just keep this amp?
Guest Posted April 26, 2010 Report Posted April 26, 2010 for the specs, that amp should do around 500-600rms so you should be fine. i dont know the 15" type AARGHH (type r nickname, like the noise a pirate makes) power handling, probably like 750rms or something, but that amp should be fine.
lem43606 Posted April 26, 2010 Report Posted April 26, 2010 the perfect amp for this is the mrp-1000 since it 2 ohm stable you will get the full 1k out of it. but anything that does at least 750rms at 2 ohm will work 2 Fi BTL N2 18s Fully LoadedSundown Audio NS-1Kenwood 845 HU Clarion EQ4 Juicebox 3100sKnu Wire"Big 3"Mechman 270a156.3dBTeam GG.
