Thanks!
Now I just have to figure out how to draft out the inside for two separate champers and get the Tune "port" right. Also I still don't know what my max mounting depth would be. I think I'm going to make the Mounting face 1 1/2" and the rest out of 3/4" or 1" MDF. Shannon
2004 Tahoe.Equipment Kenwood DNX7100 Kenwood Bluetooth adapterKenwood iPod interface cableAudiocontrol DQXSAlpine PDX 4.150Rockford Fosgate punch 40DMS Diamond Audio D363.5 (6.5" Components) Front DoorsDiamond Audio D363.5 (6.5" Components) Rear DoorsJL Audio 15w0's Subs In a 8cu. ft. Box.Monster cable XLN PRO RCA'sMonster Cable 16ga speaker wireMonster Cable 1/0,4ga power, Ground cable.I only got this Monster Cable stuff because I got it dirt cheap. (Crack Head Prices)
Thanks!
What kind of ports are you using?
well I guess the answer your looking for is "L"?  If it is possible. Shannon
Ok. Now I guess I need to determine my max mounting depth. But in order to do that I guess I need to start building this thing? Shannon
Or simply whip out the measuring tape and measure :^
Ok So would 7/16" be enough gap between the magnate and the inner wall or is any amount of gap ok? Shannon
Because of the lay back of the front of the enclosure is why I have 7/16" .  The bottom of the enclosure is 13" but the top is only 8.5" look at the CAD plans that I drew up. Thanks! Shannon
