r u talkin about from the side of the magnet or the bottom of the magnet? u should have some gap on the magnet. i hope u can fit a 12 in the 13" gap u got. i made my 10s a box that is 11" wide and i almost cut into the side of the box. check it be4 u build it.
Because of the lay back of the front of the enclosure is why I have 7/16" .  The bottom of the enclosure is 13" but the top is only 8.5" look at the CAD plans that I drew up. Thanks! Shannon
I did look and you have plenty of room.  You only need to worry about having some space behind the magnet, depending on what sub you use alot of them vent out the back as far as the sides you have nothing to worry about as long as they are not set against the wood itself
I was talking about the side of the mag to the inside of the enclosure. so as long as the mag and the enclosure is not touching I'm good. Thanks!Shannon
2004 Tahoe.Equipment Kenwood DNX7100 Kenwood Bluetooth adapterKenwood iPod interface cableAudiocontrol DQXSAlpine PDX 4.150Rockford Fosgate punch 40DMS Diamond Audio D363.5 (6.5" Components) Front DoorsDiamond Audio D363.5 (6.5" Components) Rear DoorsJL Audio 15w0's Subs In a 8cu. ft. Box.Monster cable XLN PRO RCA'sMonster Cable 16ga speaker wireMonster Cable 1/0,4ga power, Ground cable.I only got this Monster Cable stuff because I got it dirt cheap. (Crack Head Prices)
