remote switch problem
jizazz12
just finished installing my new amps, but having a problem with my remote turn on. amps are 1 crescendo audio 3kw p and a crescendo audio 1000c4, now i jumped the switch off of one amp to the other and my four channel kicks on no problem but my 3kw p go's into protect. if i disconnect the switch wire from the input terminal on the amp and reconnect it the amp comes on and stays on with no problem, but if i turn my radio off and try to turn it back on i have to go into the trunk and do the same thing with the wire again. not sure whats causing this? do i need a relay on the switch wire or is the problem with my radio? radio is a premier prs880, never had this problem be for.
2007 Chevy Impala LS
1 Crescendo 3KWP
1Crescendo C1000/4
2 DC lvl 4 15's with lvl5 dual .7 coils
1Audio Control Matrix
1 Pioneer P880PRS
1 300 amp Iraggi alt
All power runs done with Knu flex 0/1 guage
1 optima yellow top under the hood
1 XS 5100 and two Deka's in the trunk
4 Crescendo MP-8 mid bass drivers
2 DB Drive p5 5 D Pro Audio tweeters
relay will fix that and it that dont help look at the rem on the deck see if it puting out 12 volts
Edited by 01zx3
________________________________________________________________________
deepsilencer, on 22 Aug 2011 - 17:32, said:
splzx3, on 22 Aug 2011 - 17:27, said:
i had my fun on one of his videos...till he blocked me then i got my mother into it lol after her he closed the comments xD
WTF, I never thought I'd have a conversation about cross dressers and trans-genders on a car audio forum.
ran out of light tonight, i'm gonna check the voltage on the deck in the morning and see where it's at. what type of relay do i buy if thats the issue never had to use one be for?
1 Crescendo 3KWP
1Crescendo C1000/4
1 Pioneer P880PRS
thank's a lot man, i really appreciate your help.
1 Crescendo 3KWP
1Crescendo C1000/4
1 Pioneer P880PRS
np bro
how do i wire this relay, help please fighting day light.
1 Crescendo 3KWP
1Crescendo C1000/4
1 Pioneer P880PRS
found a wiring diagram on 12 volt.com hooked up the relay amp is still having same problem. should i try putting the 3k on it's own switch like a toggle or should i just send it back for warranty? i seriously never had this problem be for, all my other equipment kicks on, the other amp and my matrix and when i unplug the remote wire and plug it back in the 3k kicks on and plays like a champ but when i turn my system off i cant get it to kick back on i'm stuck any ideas.
1 Crescendo 3KWP
1Crescendo C1000/4
1 Pioneer P880PRS
01zx3 said, "relay will fix that and it that dont help look at the rem on the deck see if it puting out 12 volts" did you check the voltage from the deck? :pardon: You could try taping the power wire to see if it turns on and off. idk
Alpine CDA-9847 HU
F Highs 2x Infinity Kappa 60.9CS Powered by Eclipse EA4200 Glass door panels
R Highs Infinity Ref. 9622i powered by HU
3x RF Punch HX2 RFD2210 Powered by MTX Thunder 81000D
Box Vol. 3.259 before displacement, Tuned 36.6, Port area 54"
i did tap the power wire and that did work, did that be for wiring up the relay. thats why i'm wondering if i should just hook up a toggle switch, the relay didn't work.
1 Crescendo 3KWP
1Crescendo C1000/4
1 Pioneer P880PRS
  • Who's Online   0 Members, 0 Anonymous, 1029 Guests (See full list)
