How To Make It Better
Guest Nismofreak
ok, the rca's have an rms rating too (which is in volts). that 8v or 10v is the rms rating, just like an amp does 100 WATTS rms. if your amp cant handle the 10v rms that the eq gives out, the amp inputs will be fried. i know i wanted an epic-160, but it puts out 10v i believe, and my amp can only handle 8.
Guest Nismofreak
o I get you man...So my hifonic amp puts out only 6 volts...what would be a better eq?
the amp doesnt put out the rca volts, the eq does and the head unit does. the amp only takes it until you hook up rca's to the output. whatever the amp can handle coming in, go with something that matches it.
Guest Nismofreak
Well my hd unit has a volt input of 4 volts but have a option to disable the hd unit output volts by switching a switch bottom on the back of the head unit...
Sorry man I still don't get it...so that eclipse eq would burn my hifonic amp right? sorry man still learning
amp is rated at 6 volts
Guest Nismofreak
on the eclipse it is 10 volts that is what jason said...look at the clarion one what you think of that one?
Guest Nismofreak
Hifonics zxi 4406
the future sub amp will be a colossus XXV=9 volt output
Guest Nismofreak
what about the sub amp? that has 9 volts or just say f the eq?
  • Who's Online   1 Member, 0 Anonymous, 962 Guests (See full list)
