LEACH--77 Posted May 6, 2010 Report Share Posted May 6, 2010 Yes Ground to the frame or that will happen cuz the body will not ground it the the car sees it as a short and wont start but if you can get to your frame sand that spot down vert well and even if you need to you can always drill a new hole hope this helps you out So just finished getting everything put in and hooked up. Everything worked wonderfully. So yesterday I decided to start on my Big 3. I did the Battery to Chassis ground straight from the battery negative, to a bolt on the inside of my fender maybe 3" from the battery. That is the only one I had time to do, so I hopped in the car to leave, and it wouldn't start. It had power, but the starter wouldn't engage. I double and triple checked the terminals and everything was tight. So I took that wire off that I had just run, and the car fired right up. Any ideas? Quote 99 Tahoe Has New motor and trany has 2 12w6 with 1600watt planet audio amp im looking for the next best thing i want to have a different box so my subs will hit harder along with another amp if anyone has any ideas please let me know im open for new ones Link to comment Share on other sites More sharing options...
Twiztidsetup Posted May 6, 2010 Report Share Posted May 6, 2010 (edited) wrong post Edited May 6, 2010 by Twiztidsetup Quote Link to comment Share on other sites More sharing options...
simple1 Posted May 7, 2010 Report Share Posted May 7, 2010 i had a focus...its a uni-body so no true frame but under the battery there is a main support that runs from front bumper to under firewall...ground to it and be sure to sand paint off first. Quote Link to comment Share on other sites More sharing options...
tackett834 Posted May 7, 2010 Author Report Share Posted May 7, 2010 thanks guys. ill give it a try Quote Link to comment Share on other sites More sharing options...
kmalinich Posted May 7, 2010 Report Share Posted May 7, 2010 IIRC on the focus, the battery box is in the middle of the hood. I did a big three setup on a 4 dr focus and the shock tower was like 5" from the battery box. very convenient. Quote Link to comment Share on other sites More sharing options...
tackett834 Posted May 7, 2010 Author Report Share Posted May 7, 2010 so will the shock tower suffice? Quote Link to comment Share on other sites More sharing options...
LEACH--77 Posted May 7, 2010 Report Share Posted May 7, 2010 Can u take a pic of what your working with and I can circle the pic and show u good grounding areas Quote 99 Tahoe Has New motor and trany has 2 12w6 with 1600watt planet audio amp im looking for the next best thing i want to have a different box so my subs will hit harder along with another amp if anyone has any ideas please let me know im open for new ones Link to comment Share on other sites More sharing options...
splzx3 Posted May 10, 2010 Report Share Posted May 10, 2010 sorry bro this sliped my mind im catching up on all my stuff i have 2 do i will make a note of this and it will be the first thing in the morning Quote ________________________________________________________________________ deepsilencer, on 22 Aug 2011 - 17:32, said: splzx3, on 22 Aug 2011 - 17:27, said: i had my fun on one of his videos...till he blocked me then i got my mother into it lol after her he closed the comments xD lol your mom is a G! WTF, I never thought I'd have a conversation about cross dressers and trans-genders on a car audio forum. Link to comment Share on other sites More sharing options...
tackett834 Posted May 10, 2010 Author Report Share Posted May 10, 2010 ok thanks man Quote Link to comment Share on other sites More sharing options...
