Yes Ground to the frame or that will happen cuz the body will not ground it the the car sees it as a short and wont start but if you can get to your frame sand that spot down vert well and even if you need to you can always drill a new hole hope this helps you out
So just finished getting everything put in and hooked up. Everything worked wonderfully. So yesterday I decided to start on my Big 3. I did the Battery to Chassis ground straight from the battery negative, to a bolt on the inside of my fender maybe 3" from the battery. That is the only one I had time to do, so I hopped in the car to leave, and it wouldn't start. It had power, but the starter wouldn't engage. I double and triple checked the terminals and everything was tight. So I took that wire off that I had just run, and the car fired right up. Any ideas?
99 Tahoe
Has New motor and trany has 2 12w6 with 1600watt planet audio amp im looking for the next best thing i want to have a different box so my subs will hit harder along with another amp if anyone has any ideas please let me know im open for new ones
i had a focus...its a uni-body so no true frame but under the battery there is a main support that runs from front bumper to under firewall...ground to it and be sure to sand paint off first.
IIRC on the focus, the battery box is in the middle of the hood. I did a big three setup on a 4 dr focus and the shock tower was like 5" from the battery box. very convenient.
Can u take a pic of what your working with and I can circle the pic and show u good grounding areas
99 Tahoe
sorry bro this sliped my mind
im catching up on all my stuff i have 2 do
i will make a note of this and it will be the first thing in the morning
________________________________________________________________________
deepsilencer, on 22 Aug 2011 - 17:32, said:
splzx3, on 22 Aug 2011 - 17:27, said:
i had my fun on one of his videos...till he blocked me then i got my mother into it lol after her he closed the comments xD
WTF, I never thought I'd have a conversation about cross dressers and trans-genders on a car audio forum.
