XS Power
i have been looking into the vcm and just want to make sure everything is going to work right before i plae an order
i have a 1997 chevy suburban with the 5.7 motor and a 300 amp irraggi alt
ive got one deep cycle battery for startin and a yellow top under the hood and a kinetic hc800 in the back(uprading to two kinetic hc2400s or the xsD3100)
my voltage drops pretty bad right now
im runnin 4 crunch gpv2000.1 and 4 l7 15s
ill be changin the amps out to two kicker zx2500.1 as soon as i get the money
if i install the VCM with what i have hooked up right now what would be the best setting for it?
thank you
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
u need more battery i have the same burban and i can run 6k rms wit my stock alt and 2 walmart specials up front and 2 spv70 in the back and dont drop below 12.9. Where exactly is league tx at im in the BMT
I know a lil about everything so dont call me Mr. Know it All.
yea i know ima bout to buy either two kinetic hc2400 or two xs D3100 to put in the back and that should be more then enough power
its about 30 to 45 min away from downtown houston in the clear lake area
that should be enough. what do ya alt to at idle and is ya alt regulated internally?
I would suggest looking at changing out the battery under the hood. You will be amazed at the difference that will make. The VCM will help you out and allow you to regulate the voltage output, but your batteries are whats letting you down right now.
yeaa i actually ordered me a D3100 last night to replace my lil kinetic hc800 and ill be puttin two D3400s up front then ill order the vcm
  • 1 month later...
Sounds like you made a great decision!!!
yes sir i did i love the battery and will for sure be buying some more untill alll my batteries are XS
i plan on having two D3100 in the back and two D3400 up front
