I just recently installed two twelves in a side ported enclosure in my truck and i am trying to determine he best route for designing my new enclosure. I basically just want to get the most out of the equipment i already have since this is just a work truck/temp daily driver. I have two Kenwood KFC-W3012 subs and one Kenwood KAC-9104D amp. I'm willing to go all the way across and up to the windshield line. Basically i'm looking on opinions of whether to go sealed or ported and what tuning frequency should i use?091.jpg088.jpg
Edited by BCarter
Eye Kandy Kustomz
2414 E. Napoleon St.
Sulphur, LA 70663
(337)313-3121
[email protected]
Eye Kandy Kustomz Page
My Page
Ive done a few transmission line truck boxes, and they sound bad ass
with 1-12 its possible to get a good solid 38-40hz tuning in a tline, with room to spare on the width
I have decided on the new dimensions of the new enclosure(60"w/17"H/7"TD/11"BD)still need help on what frequency to tune the port for in a single cab truck for good spl without losing alot of sq. All help is welcome!
9/10ths of which frequency you will tune the box at is based on the size of the box, just an fyi but you can't tune anything to something. Between 30-40hz will offer you a mild sq, 40-50 low sq, and anything higher is spl based although a "Normal" person would be hard pressed to tell the difference as they would more likely than not consider anything below 120hz to be deep "Bass". Tuning freq depends on what's possible with the amount of space you've got in that box...nothing more, nothing less. Find that range out and you're golden. Good luck.
Edited by Villian88
------------167.42db @ 38hz--------------
16 Zenex HFI 12s
8 Hifonics Collusus OCA 16v
4 Powerlass 400a SW ignition HOs
Dinomat City!
what do you think of those subs? i have a pair of them too
99% of how any sub sounds is based soley on the box. Simply put, you'll be fine with those 2 subs. Get a great box built, and they'll rock louder and harder than 99% of the people that you'll run into on the street.
16 Zenex HFI 12s
Dinomat City!
thanks for the info. i have done t-lines in suv's and in trunk's but i have never done one in a single cab truck. the internal volume is 3.99cuft without bracing/displacement/port volume. i guess 40hz is going to be my goal; my current setup is at 33hz but was built for different subs.
Eye Kandy Kustomz
Sulphur, LA 70663
(337)313-3121
[email protected]
My Page
  • Who's Online   0 Members, 0 Anonymous, 1766 Guests (See full list)
