it wont go bad, he's used them in multiple installs on the 12v post , i doubt it will go bad, what should i do about the alt
2 JL W7's @ 1.5ohms - SOLD
Soundstream PCX2000D - SOLD
Yellow top Optima - SOLD
Stock Alt
148db @ 36hz
i see what ur saying it will go bad because its a 16v battery but couldnt i just use the 12v like i have it setup now, i have my power wire 0gauge from my front bat to the back so the alt can keep both charged, im not the type of person who plays my music constantly ill play it for about 30 minutes, let it charge and play again. what i want to know is its @ 14.3 idle drops to around 13.6 on music when i was testing it, after i was done testing it still read 14.3 idle, that was with both bats hooked up ect
Stock Alt
148db @ 36hz
ok bro just edit ur post stop makeing new ones
the mods dont like it
and yes it will go bad if u dont keep it chaged and it a waste just sale it and get a 12 volt battery (no 16 volt added on to it)
________________________________________________________________________
deepsilencer, on 22 Aug 2011 - 17:32, said:
splzx3, on 22 Aug 2011 - 17:27, said:
i had my fun on one of his videos...till he blocked me then i got my mother into it lol after her he closed the comments xD
WTF, I never thought I'd have a conversation about cross dressers and trans-genders on a car audio forum.
You are only using a portion of the battery to run a 12V system. If you are only charging at 12V, you are getting shit for voltage anyways. Even charging the 16v post at ~17.5v-17.8v, I am only seeing 12.1-12.2v on the 12v side.
That is how it will be due to how that battery works..... the 12 volt post on the battery is only using part of the battery, only some of the cells, to supply 12v. Then all of the cells are used to supply the 16v. The alt is supposed to be keeping the voltage up on the 16 volt side, so your 12V side gets charged, although weak anyways. You are only charging certain cells and seeing a higher voltage, while the rest of your battery is neglected. They are designed for 16V application.
But what do we know. Why don't you just ask your 'experienced' buddy rather than telling us we're wrong?
Edited by Neo_frog
Need an install? Hit me up.
[email protected]
lol neo just took my next post thank.... :angry: lol jp bro
ya dont come here asking us for help then tell us we are wrong
u just have moved 2 my dont help list
It's ridiculous right? They need help, then shoot down all advice cause either they know or their buddy's know better. w/e I'm out.
[email protected]
well im probably about 40 miles from indy, i didnt need you to get an attitude about it, i just needed input on the batts my buddy bought one also and he's had his running in his car for 2 years, something must be wrong there i guess, haha anyways, i guess ill get a different battery but the main reason was a alternator , there is alternators that will charge 16v batterys with ease.
Stock Alt
148db @ 36hz
16 volts is over ur head if u have a idea of 12 volt
im not using the 16v post, only for burps, i also have a kinetik charger for the batt, i dont know why people always have to assume there opinion and be so negative about it im sorry that you have no friends bro.
Stock Alt
148db @ 36hz
lol i have friends here bro
im in just answering ur alt qustion about 16 volts
like i said be4 just sale it and get just a 12 volt battery and keep it easy
  • Who's Online   0 Members, 0 Anonymous, 2504 Guests (See full list)
