Hello guys, I have assembled a sound on my PC, just like in the picture with the following equipment:
Pioneer P6850MP
AMP 480rms Band for bass, one on each SUB Bridge
Buster B. AMP 1600W 400rms to middleweight.
Source Audio BL 140A
MAX Battery 70A
Front speakers =
2 5x7 "Buster
2 Coaxial 5 "N.A.R
Rear speakers =
2 Pioneer 6x9 6993S
I have two subs NAR Audio 180rms each of the following specification =
Box I use is 38L each chamber.
Diameter = 12 "
Power 180W rms =
FS = 23,80hz
QES = 0.592
QMS = 4.024
QTS = 0.516
VAS - Lts = 190.0
Xmax = 7.5 mm
in -% = 0.419
Sens 1w / m = 88.24
Sd = 53.093 m2
Le = 3.2 mH
Re = 3.3
BL - T.M = 8.85
Impedance 4ohms =
> Based on these parameters, can someone calculate the measures and pass me a box that it is excellent for this SUB?
Thank you. :D
Edited by lacerda88
Haha! I've been running a kicker amp on a 10 in the house on my computer for almost 2 years. A simple little power 400 watt pc power supply powers the amp. It sounds really good.
Kicker KX 200.4 bridged on a dual 4 ohm mtx sub in a radio shack pa box with crossover. Tweeter disconnected.
Edited by scottx
Loud and Clean - 1985 190e 2.3 Audio Show Car - Champagne Dream.
Would you happen to have a wiring diagram of how you wired everything up?
On 2/28/2013 at 2:52 PM, Chaise said:
"Now spread your butt cheeks so I can zap your asshole."
  • 1 month later...
Anyone can calculate a box for my SUBS with the following parameters?
Thank you!
Diameter = 12 "
Power 180W rms =
FS = 23,80hz
QES = 0.592
QMS = 4.024
QTS = 0.516
VAS - Lts = 190.0
Xmax = 7.5 mm
in -% = 0.419
Sens 1w / m = 88.24
Sd = 53.093 m2
Le = 3.2 mH
Re = 3.3
BL - T.M = 8.85
Impedance 4ohms
Thank you!
Diameter = 12 "
Power 180W rms =
FS = 23,80hz
QES = 0.592
QMS = 4.024
QTS = 0.516
VAS - Lts = 190.0
Xmax = 7.5 mm
in -% = 0.419
Sens 1w / m = 88.24
Sd = 53.093 m2
Le = 3.2 mH
Re = 3.3
BL - T.M = 8.85
Impedance 4ohms
Make it 500mm x 500mm x 400mm then its tuned to 30hz
Dimensions are internal
Box for one sub is 100l
Edited by Explorer
  • 1 month later...
how u keep the battery charged? nice setup btw
I think its the power supply in the picture at the bottum charging the battery.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
Hello staff, the source is black in the picture with the name BL AUDIO. She has 140A and maintains the battery charge, for use only with the sound attached to it.
About my question, the ideal is to make a box for each sub with 100L?
I'll have a good quality with my subs?
thanks.
  • 3 weeks later...
  • Who's Online   0 Members, 0 Anonymous, 2983 Guests (See full list)
