External Regulator
Hey guys, just did the big 3 on my 1988 Honda City, and I noticed it has an external regulator up next to the battery.
I recently got my voltmeter installed in the car and have noticed that when the lights are on I get a substantial increase in the voltage. From 12.9 to 13.4/6 I was wondering If I could trip the regulator into thinking the lights are on all the time for the extra voltage or if I can boost it up to about 14.4-14.6. How does a regulator work? It has alot of copper windings in it and an audible relayfor when the car is turned on or off.
Thanks!
1988 Honda City E
  • Big 3 in 1/0
  • Venom 6x9
  • Venom 6.5 Components
  • Response 4x100 midz and highs amp
  • Fusion NV 2500.1: STOLEN
  • 2 x 12 inch fusion nv subs
  • 10 inch 5 doller subs in my doors
PM me if you want help with electrical
There is no computers at all on my car. Its a carb engine and a very old jap. It says regulator on the side.
1988 Honda City E
  • Big 3 in 1/0
  • Venom 6x9
Oh I thought it said 98 my bad.
I wouldn't suggest trying to modify an old regulator. Basically it measures the input voltage constantly, then closes a circuit to the field wire of the alternator which will charge with a proportionate voltage. Inside there is a reference voltage which is uses for it's comparison.
I don't know if yours is old enough to still use the mechanical portion or just diodes. Either way, I couldn't tell you how to modify it because I'm not sure.
Need an install? Hit me up.
[email protected]
It is a mechanical regulator, I am game to try this cause I do have a spare one. What circuit does it close? Its a 2 pin alternator.
ALSO, because I did the big 3 from alternator straight to the battery by passing the regulator, will it damage anything?
1988 Honda City E
  • Big 3 in 1/0
  • Venom 6x9
in that case why dont you just try to add the other to the car?if you can weld i'm sure you can fab up one.
  • Who's Online   0 Members, 0 Anonymous, 1405 Guests (See full list)
