http://www.sonicelectronix.com/item_7342.html
can this battery be used in place of my normal battery, and is it better the a yellow top. Street A, B you can only use 1 battery, so I can oly use 1 battery I will have 2000Rms
Sorry for teh Noob question I just want to make sure.
SMDsigbannr4.jpg1995 Geo Prism . FI BTL 12 P chamfer, 3rdmagnet HIXMAX COIL 1/0 big 3 HIFONICS COLOSSUS 1.7 cubs tuned to 60hz in the works 2xTruck battery 1125 cca.
triple posting noob
NoFearX18 said:
trainman0978 said:
Guest 90accordman
When talking to a Kinetik Rep they say no, but I;ve seen a couple up there lol.
triple posting noob
yaa sorry dang computor froze and i keep clicking
yaa i just don't want it to explode or anything
Guest 90accordman
i'd tend to go with that the rep reccomends as if somethign happens i doubt they are gonna replace your stuff
http://www.kinetikaudio.com/calc.asp
if ou put in that you are going to replace your starter battery it brings up what Kinetik battery you need for you starter and for your amplifers. so I guess that gets rid if the will it be ok question.
so is the http://www.sonicelectronix.com/item_7342.html a better starter battery then the a Yellow top d-35?
Guest 90accordman
if you go optima go red top for starter battery
I still dont understand why thier calculator wants me to run 2 1800 batterys and my optima for a 2200rms system, sems a little overkill imo but its only under 500 for them so i guess i'll see how it works out.
Thanks for your interest in KINETIK...  The HC1800 can be used to start the vehicle.  The benefit would be the increased peak power needed at ignition. as well as more amp hour reserve time for your accessories!
Thanks
Erik
Kentik rep said it was cool he works for the main company =) so kinetik it is :^
  • Who's Online   0 Members, 0 Anonymous, 4546 Guests (See full list)
