fazio93 Posted May 11, 2010 Report Posted May 11, 2010 If Voltage of the output = sqrt(RMS Power X impedance of the speaker) I have a Kicker 12" 800 Watt 4 Ohm Dual Voice Coil Comp VR. I have it bridged down to 2 ohms. But if I want to determine the needed output voltage from the amp, would I use the 4ohms that the sub is rated for (which would make the needed voltage 40 V) or do I use the 2ohms that I have it set it up at (which would make the needed voltage ~28 V) Thanks
IH8PunkRok Posted May 11, 2010 Report Posted May 11, 2010 if its wired to 2 ohms then thats the number you need to use -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
hdorre Posted May 11, 2010 Report Posted May 11, 2010 if its wired to 2 ohms then thats the number you need to use x2 On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
TeejayBee Posted May 11, 2010 Report Posted May 11, 2010 You dont have it bridged down you have it wired in parallel from dual 4 to 2 ohm final load and use this chart http://i53.photobucket.com/albums/g42/Krannyman92/rmschartpm5.jpg
