Hey guys, it seems ever since I got a new Modem that every time my computer goes to sleep I loose my wireless connection. The only way I have found to get it back is to unplug the wireless router and plug it back in. I dont get it and its starting to get really fucking old. Every time I sit down to get online I have to get right back up and go to the modem to reset it. Any ideas I can try when I get home?
d(-__-)b
beer sucks...but i can bring some jose cuervo. Only problem is that it makes me horny and gives me the rams. So unless yall wanna fight and then have some great make up sex i will leave it home.
disable wireless turning off when entering sleep mode.
Hammerdown... 1%
  • 1 month later...
I bet your running Vista!! That is a known Vista problem, the best workaraound in to go to Win 7 unfortunatly... I was plagued with that with Vista and could not really ever find a rock solid fix that lasted...
Something I had happen on a job, the router was on the same channel as thier neighbors and they were having wierd things happen, such as dropped connections, page can't be displayed and random disconnects from the router. Try changing the wireless channel on the router to a non standard channel such as channel 2 or 3 and while ur in there, if the wireless network is using the standard SSID name, re "linksys" or "netgear", change it. I also seen issues if you have an unsecure wireless network, re: no encryption and key to connect. good luck bro... as I said, I was plagued by same issue and drove me fucking crazy!
