2 Monster 12s Like New: $250 each
So up for sale are some 12s out of a system I did for my dad awhile back, they were only played at low volume, he only really played loud them a few times, they are really stiff. They were seeing 2000wrms of clean unclipped power.
$350+shipping EACH $250+shipping each, will do a deal for someone who buys both!!! They weigh 75lbs EACH and my zip is 26726, these are like new and were scoped to they werent clipped. Also I payed $650 for one and $585 for the other, they were purchased new.
Here's the specs:
Features:
* Interlaced Carbon Fiber Reinforced IMPP Cone Woofer
* Wide-Roll, Woven Aramid Fiber Radial Rubber Surround
* Overhung Surround Design
* Ceramic-Coated Voice Coil Wire
* Titanium Voice Coil Former
* Dual 3", High Inductance, 4-Layer, Long Voice Coil
(2 x 2ohm)
* 7-Slit Glass Imide Voice Coil Bobbin
* Precision Double Conex Damper with Damper Rings
* Projected Pole Yoke with Vented Pole
* Aerodynamic Magnetic Gap (ADMG) Design
* Massive (320 oz.) Triple Stacked Magnets
* Thick 1.2" (30mm) Top Plate
* Aluminum Die-Cast One-Piece Rigid Chassis
* 8-Gauge Wire Terminal
Specifications
* 6000 Watts Max. Music Power
* 2500 Watts Nominal Power Handling
* Dual Voice Coil Design (1ohm or 4ohm)
* Frequency Response: 18 - 2kHz
* Sensitivity: 88dB (1W/1m)
* Recommended Enclosure: 1.5 Cubic Feet
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
It's gonna cost exactly $100 to ship both... I'll get back to you.
My YouTube Videos
I'll go half on shipping which means $750shipped to you.
My YouTube Videos
No mean to post dump. If I had the money and was in need of some monster 12's I would most definitely pick these up. To anyone looking for a great set of monster 12's this is a great deal for these. You should also know you would own a part of what is left of the Premier line.
Thanks man, they don't just get loud but they sound amazing too!
My YouTube Videos
what would the box specs need to be on these subs?
3ft^3(excellent SQ) sealed and for ported I'd run 5ft^3 @ 35hz ~80sqinches of port area and thats for a pair half that for 1.
My YouTube Videos
bump for some CF goodness...
My YouTube Videos
