quality of parts, design of woofer, and build quality make a sub good or bad.
Doubling cone? no, dont do that.
A good cone will match to your suspension. Most of the time you want a strong, stiff, rigid yet light cone. Carbon fiber tends to be top of the line. Pressed paper is good too. Lightweight is important.
A straight cone is better for SPL whereas a parabolic shape is better for SQ.
Suspension parts must be tuned for your cone, coil, and motor. Simply adding spiders is not good. There are various types of spiders made of different materials that have different tensions, stiffnesses, rate of rolls, and sizes. Best to match type and qty to the tension of suspension you want for your motor force and cone and coil weight.
Coils are important for power handling and weight. There are a few different type of material. Copper is basic but has good SQ characteristics as well as can be made for good power handling. Aluminum is lighter and great with heat, but raises Fs of a driver.
Basically a good design has well balanced parts. Finding that balance can take years of experience and knowledge of materials and woofer engineering.
Its the HFI?
Is that a 2" coil.
You cant really make an entry level sub better without basically building an entirely new woofer.
The motor is very small and just adding spiders would reduce efficiency and most likely raise Fs, taking away SQ potential.
You can add a taller coil if they exist, but again that would reduce efficiency for the sake of adding 10% more power handling.
I say, buy a new motor and a frame that can handle larger spiders and has more clearance for cone travel. Basically, use a different woofer.
If you are just experimenting, that good. But that woofer is not a good platform, get a good 3" coil motor to play around with.
free expert advise here
816-591-6592
www.kcrimshop.com
Love
My POS Bass machine-
2003 Hyundai Santa Fe on some shitty 22's
Bed Liner Paint Job-Pioneer AVH 3200DVD
4 DAD BD series 15's in a 4th Order (Bassheads ENT Design)
4 Arc Audio XDI2000.1 for the woofers
6 Cadence CVL68MBX 6.5's-Cadence CVL88MBX 8's-6 Cadence XT20 Supertweeters
2 Arc Audio KS300.4's for mids and tweets
1 Arc Audio ALD 10v Line Driver
All Audiotechnix Power wire
1 DC Power 270XP High Output Alternator
1 XS Power D3400 up front....6 XS Power D3100's in the rear
Air Lift 1000 Bags in rear to help with suspension
If your still reading this GFY.......
  • Who's Online   0 Members, 0 Anonymous, 1703 Guests (See full list)
