XS Power
its make it where u can adjust voltage from 14v up to 20v(iirc)
more input power = more power outta ur amps
2004 Yellow F150 STX 4x4 Single Cab
2 Yellow DC Power 270SP's Alts
4(and counting) XS Power 6500's
4 DD3515s Supercharged
53cu.ft 4th order blowthrough
8 DD M1b's
6 Selenium 8's
2 Selenium ST350s
154.1 @ 41hz Legal Burp
Build Log
All it does is regulate the current voltage coming out of the alternator. As you increase the value of the desired voltage, it sends slightly higher voltages to the field wire of the alternator. As a result, the alt will charge higher. If you are using an MLA module, it just changes the charging curve based on your PCM.
Need an install? Hit me up.
[email protected]
  • Who's Online   0 Members, 0 Anonymous, 987 Guests (See full list)
