Most use stainless steel bolts. The bolts are very convenient. I suggest using a lock washer on the inside also so there's a higher sustainability of abuse without coming loose.
Need an install? Hit me up.
[email protected]
For my upcoming build I will be using some all thread bent in an L-shape. I will drill two holes in the back of my box and one end will use a nut to connect to the wires on the inside, and the L parts will fit directly into the speaker terminals, eliminating a second connection.
¿ǝɯɐƃ ǝɥʇ
