I wanna see how you guys are running your wires from the inside of the box out. i usually just run the wires out the port but i wanna make this box look good. so any input will help thanks guys
Just drill a hole, run the wires, and seal it (caulk)
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
i just go to home depot and pick up some bolts and 2 nuts per bolt, and enough crimp connectors to fit the wire and said bolts. attach wire to the inside with the head of the bolt, then put a nut on the outside. connect the amp to the bolts and put on the second nut. done.
yeah i thought that. thanks man. what size wire you running to your subs from your amp
12 gauge, but it's only on 500watts
LMFAO so true
:blush:
I use bolts, they work great :yahoo:
8g as speaker wire FTW! to connect it thru the box i used plain bolts,nuts and washers...then a wing nut for easy access :-)
Just any bolt?
Grab some ring terminals for your wire and then bring one to the hardware store with you. Try out bolts until you find one thats the right size for the terminal and is also long enough to fit through the box.
wtf is lolcats?
I'd def get a fat hooker if i had to resort to that kinda thing. I feel like they'd be grateful and work harder. Also its more bang for my buck, more real estate for my dollar if you catch my drift. its like the Costco of streetwalkers.
I was hoping for 150 :(.
I was hoping she would let me put it in her butt
  • Who's Online   0 Members, 0 Anonymous, 1477 Guests (See full list)
