manofthehour Posted May 21, 2010 Report Posted May 21, 2010 I've decided just to upgrade to one 15" RE Audio SEX dual 2 ohm sub. I'm getting the AQ1200D to power it. Does that sound like it would hit harder than two 12" Terminators on 340 watts RMS? I'm also wondering if you can wire a dual 2 ohm sub to a 1 ohm load. Thanks. My stuff '06 Scion xA: -Alpine iDa-x100 -Alpine KTP-445 Power Pack -Polk Audio db6501 (front components) -Polk Audio db651 (back coaxials) -2 RE Audio SEX12D4s -Cadence F1200-1D - Custom box tuned to 33Hz - Kinetik HC1400 - 50 ft2 of Audio Technix sound deadner - Big 3 My photography page
Socky Posted May 21, 2010 Report Posted May 21, 2010 Yes it will be louder than the two 12's. You can run a 1 ohm by running positive to positive, negative to negative. if you port it, i would suggest 32 hz so it will slam the lows Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell Kenwood H/U 1/0 wire, 136 amp alt 200 ah batteries 12.7 daily 2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts Mb quart 125.4 wired to 4 aura 6's 3.6 cube box tuned to 36 plays down to 23hz
