So as promised I did a lil clamp test, I want some feedback, and to know if my numbers look good.
First the pics, then the #'s
Thanks P4Killer
The numbers:
This is what I came up with:
its AC Volts/ AC Amps = Ohm load
(AC Volts * AC Volts)/ Ohm load = wattage
Hz--AcV--AcA--Vol--Ohm--Watts
30--43--48.8--47--0.88--2101.1
32--47.8--43.4--47--1.01--2262.2
35--49.2--50.1--47--.982--2465
40--50.8--47.1--47--1.078--2393.9
43--53.4--49.6--47--1.076--2650.15
45--43.7--50.1--47--.8722--2189.5
50--39--16--47--2.44--623.4
Notes: I tried to use my drill to keep the RPM at 2k but it really didnt stay
Also, the reading right at unpause were higher, but i usually waited 2 sec to make my reading sometmes like 4-5 sec so maybe my numbers are a lil low at some Freq.
For instance at 40Hz, my first readings were 50.8 AcV and 50.1 AcA but I re did it at the end and got the numbers posted above
Also I didnt charge the batts before hand and only waited maybe a min maybe between burps
So did I do this right?
What do you think?
Also my voltage drop at higher freq is minimal at low Freq. is sometimes severe. Usually ~ 11.5v but I have seen like ~10.5v
Lemme know
P4killer
Edit: Spelling
Edited by P4killer_
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
Now that I think about it this should be in the amp section. Move please?
Setup:
Xs D3400/ Xs XP3000
