Team-Atomic-Andrew Posted May 23, 2010 Report Share Posted May 23, 2010 ok so im doing a home theater setup for myself specs on the speaker is as follows * Power handling: 500 watts RMS/800 watts max * VCdia: 2-1/2" * Le: 1.00 mH * Impedance: 4 ohms * Re: 3.3 ohms * Frequency range: 18 - 800 Hz * Fs: 18 Hz * Magnet weight: 150 oz. * SPL: 90 dB 2.83 V/1m, 87 dB 1W/1m * Vas: 9.95 cu. ft. * Qms: 3.10 * Qes: .49 * Qts: .42 * Xmax: 14mm * Sd: 14-1/2" its a dayton refrence series 15 HF i already know the port needs to be 15' 8.25" long and 150'sq in of port i just need to know the volume of the box i should use and any suggestions to improve this will be helpful Link to comment Share on other sites More sharing options...
CheezyMane13 Posted May 23, 2010 Report Share Posted May 23, 2010 ok so im doing a home theater setup for myself specs on the speaker is as follows * Power handling: 500 watts RMS/800 watts max * VCdia: 2-1/2" * Le: 1.00 mH * Impedance: 4 ohms * Re: 3.3 ohms * Frequency range: 18 - 800 Hz * Fs: 18 Hz * Magnet weight: 150 oz. * SPL: 90 dB 2.83 V/1m, 87 dB 1W/1m * Vas: 9.95 cu. ft. * Qms: 3.10 * Qes: .49 * Qts: .42 * Xmax: 14mm * Sd: 14-1/2" its a dayton refrence series 15 HF i already know the port needs to be 15' 8.25" long and 150'sq in of port i just need to know the volume of the box i should use and any suggestions to improve this will be helpful Well realistically Your gonna need to have many fold in the box, and you sub is gonna be mounted in the same area as the rest of the port area. Check out my build in my sig, I'm having three T-Lines in my car, take baby steps, u cant do it all at once unless u have a roll of 100's big enough to choke a donkey 1998 Chevy Venture "Swagger Wagon" Kenwood Excelon KDC-X994 Headunit 3 15" Alpine Type R's in seperate T-Lines 1 RF T1500-1bd for 2 of the 15s 1 RF P1000-1bd for the single 15 3 sets of Hifonics Zeus ZXi6.5C Components( 1 more set to come for Front stage) 1 Hifonics HFi100.4 4-channel amp Stock alt for now (DC HO SPL 400A when funds come in,currently working on buying this) Stock battery and one Optima Redtop for now (looking at XS batteries) 3 15" Alpine Type R's (aka Swagger Wagon Build 1.0) Swagger Wagon Build 2.0 Youtube Videos Link to comment Share on other sites More sharing options...
