ok so im onto box number 3 for the DDs
ive tried an ABC box which failed
a 4cube at 38 hz ( current box doing a 146@41hz)
and the new box
which will be 4.8@ 39-40 hz with 106 square inchs of port
each sub will see roughly 3k
box is in the trunk facing forward seald from trunk
how will it be.. .compared to teh 4 cube box?
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
Try firing your subs to the rear you'll get less cancelation that way. and your scores should be higher. Its probably not your box but the orientation of that box
1998 Plymouth Voyager (daily)
Jensen VM9213 H.U. (I Know but I havent had any problems.... yet)
5.25" Factory -> Sound Stream SST5.2
6x9 Hifonics ZXi 693 -> Sound Stream SST6.9
Amp: Class D: Crescendo 3KWP (x2)
Class A/B: Crescendo 1000C4
Sub: Almani S-7 10" (x6)
no room to fire to teh rear
box will be 14 tall 31 deep and 36 wide
with it 31 deep the box acctually hits the rear of the car and i have maybe an inch between the box and my back seats haha
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
not always. You need to seal off the box well front and back and you should be louder forward firing.
Fox try sliding the box back and forth you may need to have it back a few inches to find the optimal spot.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
i can only move it maybe half an inch befor subs will hit the seat while playing music and such and myabe an inch side to side other then that... i cant move it it literally takes up the intire trunk of the car! haah
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
How big and what was the port area for the other boxes? Is your rear deck sealed as well as around the box? That area should be sealed as tightly as you can get it if your going this route.
That port area is BIG but I agree with you tuning up around 40hz like DD recommends.
ill be sealing rear deck once the box comes out thats all thats left to seal up
current box is 4 cubes at 38 with 78 square inches of port
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
Thats a lot of port area too. Ever consider shrinking it down to 16 per cube and seeing if there is a difference. Easy to do and dont need a new box to do it. I would seal that deck off for sure. Helped a lot in our Mazda.
  • Who's Online   0 Members, 1 Anonymous (See full list)
