What I have here is a few items for sale for a buddy of mine. He has decided to go a different route on his build and doesn't need this equipment collecting dust. All of it is brand new and never used. Amp and Component Sets are still in original packaging and have not seen power. Battery was taken out of packaging to inspect. All these items are for sale only. Do not offer me trades as I am not interested unless its a nice headunit that can run active. All items will be shipped via USPS standard shipping unless you pay extra for quicker shipping. Need this stuff gone as soon as possible! All prices are "Or Best Offer"
Two 5.25 Phoenix Gold component sets *SOLD SOLD SOLD SOLD*
  • RSd 5-1/4" Component System
  • Injection Molded, Aluminum Plated Polypropylene Cone
  • Butyl Rubber Surround
  • Rigid Powder Coated Steel Frame
  • Interwoven Tinsel Leads
  • Optimized Magnet/Motor Structure
  • 20mm Broad Dispersion Silk Dome Tweeter
  • Power Handling:
    • 60 watts RMS
    • 120 watts Peak
    [*]Sensitivity: 86 dB[*]Frequency Response: 65 Hz - 20 kHz[*]Mounting Depth: 2.4"[*]4 Ohm Impedance
$40 each + shipping
PowerBass ASA 600.4x *SOLD SOLD SOLD SOLD*
Auto Sound 4-Channel Class A/B Car Amplifier<li>RMS Power Rating:
  • 4 ohms: 100 watts x 4 chan.
  • 2 ohms: 200 watts x 4 chan.
  • Bridged, 4 ohms: 400 watts x 2 chan.
  • Max power output: 1600 watts
  • MOSFET power supply
  • LED power and protect indicators
  • Bass Boost/EQ details (0-18 dB bass boost at 40 Hz)
  • 4/3/2 channel operation
  • Preamp RCA outputs
  • 3-Way System Protection circuitry (thermal, overload, and speaker short protection)
  • Heavy duty aluminum alloy ribbed heatsink for maximum heat dissipation
  • Silver-plated RCA level inputs
  • Silver-plated screw terminals
  • Variable high-pass filter (40-250 Hz, 12 dB/octave)
  • Variable low-pass filter (40-250 Hz, 12 dB/octave)
  • Damping Factor: >150
  • Frequency response: 20-20,000 Hz
  • Dimensions: 15"L x 9-5/16"W x 2"H
  • 4-gauge power and ground wiring is required for installation.
$140 + shipping
SPV20 Stinger Battery (small)
  • Temperature range: -15C to + 50C
  • Typical Cycle Life: 350 cycles @ 100% depth of discharge (10.5v)
  • Maximum Charging Voltage:
  • 15 Volts (Cyclic Use) 13.8 Volts (Standby Use)
$100 + shipping
-John
Edited by John
1999 Chevy Tahoe
Level 4 15"
AP 3000d
Rockford and Phoenix Gold Componets
T400.2
Mechman 250 amp Rhino
2 Kinetik 2400
GET LOUD : STAY LOUD : SLAP RESPONSIBLY
ill take one of the conponet sets from ya, pm me lowest price shipped to 57401
wow now this just shows that smd isnt just any forum. We are a brother hood.
here let me put it in retard-onix for u aareehhhh duuuurrrrr ehhh got it now?
Sweet baby jesus the amount of quoting the quote above the quote in a quote is epic
PM sent
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
pm's sent to all. The two component sets are pending at the moment. Really need to get the rest sold quick!
1999 Chevy Tahoe
Level 4 15"
AP 3000d
T400.2
2 Kinetik 2400
PM sent to you killallblue, sorry missed ya last night, both sets are still up for grabs. OBO on battery and amp. Cheap little setup for the girlfriends fella's, lets get these sold! clapping.gif
1999 Chevy Tahoe
Level 4 15"
AP 3000d
T400.2
2 Kinetik 2400
This topic is now closed to further replies.
