Hey so I called again and this setup sounded easier.... slightly
http://www.crutchfield.com/p_211ZN5Y2F/StreetWires-Zero-Noise-5-Y-adapters.html?search=y+adapters&ssi=0
1 male 2 female.
What do you guys think of this? I guess I plug these into the back of the pre amp outs? so then it's like I have 2?
1 male 2 female.
anyone thinks this makes more sense than the 2 male 1 female?
Posted (edited)
Thats pretty much the same thing. Only reason i would even remotely say could cause a little prob is now you have 2 sets of rcas running to the amp so youll need another set of rcas and a little more chance to pick up noise. No biggie at all either will work, but if you use the ys at the amp you have one set of rcas and 2 y splitters thats it?
http://www.crutchfield.com/p_211ZN5Y2M/StreetWires-Zero-Noise-5-Y-adapters.html?search=y+adapters&ssi=0
use that
Edited by AKBass
Current
Ford F350
Alpine IVA-W505
2x Diamond s600
1x Diamond S400
2x RF T1500-1BD
1x RF T600-4
2x AA Havoc 12"
DC Power 230XP
1/0 throughout
Up Next
95 2dr Tahoe
Head Unit= Alpine IVA-W505
Components= 2 Diamond S400, 2 Diamond S500, 2 Diamond S600
Woofers= 2 10" Diamond Hex, 2 12" Diamond D9
Amps= 3 RF T1000-4
Processor= 2 RF 3sixty.2
Subs= 4 18" AA Mayhem
Amps 4 RF T2500-1 BDCP
7 XS Power D3100
3 DC Power 270+
I'm buying a 4 channel amp kit. So I have 2 sets of RCA's. Thats enough right?
B/c when people say sets do they mean how one cable has 2 rca's at each end or literally a set of 2 cable?
Posted (edited)
i set of rcas= 1 cable two wires, some people may see it diff but thats the way i say it. or just RCAs
if you already gotz 2 sets of rcas then use the one you posted 1 male 2 female
Edited by AKBass
Current
Ford F350
Alpine IVA-W505
2x Diamond s600
1x Diamond S400
2x RF T1500-1BD
1x RF T600-4
2x AA Havoc 12"
DC Power 230XP
1/0 throughout
Up Next
95 2dr Tahoe
Amps= 3 RF T1000-4
7 XS Power D3100
3 DC Power 270+
Thanks for the help!! I'll buy the one I just posted then.
Here is the amp kit Imma use just for reference.
http://www.audiosavings.com/products/Amp-Installation-Kit/DB-LINK-4-GAUGE-4-CHANNEL-CAR-AMP-INSTALL-KIT-4-CH.-RCA/XK4B2.aspx
btw: about the EQ, I can't rly afford one at this time. I'll get one once I upgrade to the next car.
http://www.audiosavi...-RCA/XK4B2.aspx
[/quot
Is this your first amp install? A few tips if it is
Keep low level away from high level i.e. rcas away from power and spkr wire
scrape paint away from grounding area keep grounds as short as possible
make sure your polarity on fronts is correct/ wrong polarity=no mid bass
nothin special but it will save you time and noise in the long run
Current
Ford F350
Alpine IVA-W505
2x Diamond s600
1x Diamond S400
2x RF T1500-1BD
1x RF T600-4
2x AA Havoc 12"
DC Power 230XP
1/0 throughout
Up Next
95 2dr Tahoe
Amps= 3 RF T1000-4
7 XS Power D3100
3 DC Power 270+
Posted (edited)
[/quot
O man I think that explains it! I feel my car has very little mid bass and thats prob. b/c I installed the front speakers wrong. lol ok. THANKS! I'm debating doing it myself or taking it to a shop.
I'd be putting in a 10 inch sub also. For the install I've been quoted 160-180$. Is that the avg. price? I was told like 90$ originally but then I mentioned I wanted the other 2 channels wired to the front speakers and thats apparently add the rest on.
btw, the guy at crutchfield said I should get a ground terminal. Is this needed? B/c it's like 12 bucks and then shipping. So if this isnt essential or like a really good safety measure I don't wanna get it.
http://www.crutchfield.com/p_211GT14/StreetWires-GT14.html?search=grounding+terminals&ssi=0
Edited by Moofs
Posted (edited)
if you dont want to spend the money no. just get a bolt or screw the same diameter as the ring connector. Its best to ground to the frame if possible but not always necessary. Just make sure if you ground to the body under carpet somewhere scrape the paint clean past the primer to clean metal, dont ground to painted or dirty surface.
Watch, now the whole seatbolt or seatbelt bolt vs. body vs frame debate will start.
Yeah that price is right in line. Its usually cheaper if you buy the equipt from the shop, not much, but a little.
This is a real good forum(SMD) for getting started with building your first or most recent system, from what i have read there are quite a few very knowledgeable people willing to help. Im always stoked to see someone that wants to learn(and doesnt have any bad habits from previous teachers) you could prolly do it yourself but if you feel more comfortable have someone else do it then take it apart to see how they did it.
Have Fun
Edited by AKBass
Current
Ford F350
Alpine IVA-W505
2x Diamond s600
1x Diamond S400
2x RF T1500-1BD
1x RF T600-4
2x AA Havoc 12"
DC Power 230XP
1/0 throughout
Up Next
95 2dr Tahoe
Amps= 3 RF T1000-4
7 XS Power D3100
3 DC Power 270+
