Using audacity to tweak Freq...
Can someone point me in the right direction for a good tutorial on how to use audacity to tweak frequencies... I'm thinking that an adjustment on "Shining Star" by Earth Wind and Fire could use a bit of a tune up!
Ride - 2006 Scion xB
Equipment:
H.U. - Kenwood KDC-X793
Amps - Memphis 16-MC2.100
Memphis 16-MC1.1100
Front Stage - Memphis 15-MCC6 6.5 Components with silk dome tweets
Subs - Memphis 15-M310D4 10" Sub (x2)
Custom box 3.02 ft3 after displacement, tuned to 37 hz
Big 3
Second Skin Damplifier
Coming soon:
Kinetik HC1400
H.O. Alt
AudioControl three.1
Open the song in Audacity.
Find the part of the song with the note that you like.
Highlight that part of the song.
Go to Analyze, then Plot Spectrum.
On the Frequency Analysis window:
Change the settings from 512 to 1634 & change Linear Frequency to Log Frequency.
You will be able to see all of the peaks as well as the loudest singe note on the graph.
Remember that / those frequencies.
Close Frequency Analysis.
Go to Effect, then Bass Boost.
Put in the frequency you want to boost and by how many DB.
NOTE: it is really really easy to make things one notish like this, and be very careful not too boost too much. You will know you have boosted too much when your boosted notes cause the track to clip. This is obviously bad- so don't boost them too much, or the track gets dirty.
Happy Tweaking! :drinks:
12 - 12"s in the STAY PUFT 1989 Chevy Astro
Build & Comment Log
Un-Interrupted Build Log
YouTube Channel
Chevy Trailblazer 5.1 Dolby Digital DTS Install
You have a beard of a mysterious sea captain. I would follow you to hell and back.
well that helps him too colin but i think what hes asking is how to change the hz of the note
so you need to follow colin's tut he posted and when you find your frequency you go under effects and choose change speed.
either drag it to + or - depending on if you want the freq higher (+) or lower (-) this also speeds or slows the song down. about -8 is taking it down 4hz but you might have to play with it to get it right. and just keep checking plot spectrum after you change the speed.
ive never done it this way, but you might also be able to do it changing the pitch under effects also.
sounds cleaner imo to slow it down though :good:
my system
2 12" diamond d3 subs
Kenwood 500 watt class d mono amp
On 4/14/2010 at 5:40 PM, Boon said:
Waaaaaa my system has a minor issue that I can't figure out so I'm gonna quit audio.
Fucking weak man.
Yeah, in one of his threads Decaf said it is better to slow a song than to change the pitch. And chrispy I believe you are right too- it sounds better slowed than changing the pitch.
So you can boost frequencies and change them too. :D
Build & Comment Log
YouTube Channel
Right, that way the rest of the sounds in the song are "right" for the bass your boosting
  • 11 months later...
thanks a lot bro. i followed ur steps and now i understand the whole process
  • Who's Online   1 Member, 0 Anonymous, 555 Guests (See full list)
