white4d96 Posted June 1, 2010 Report Posted June 1, 2010 I have a Kicker KX800.4 that has issues with its power and ground block. Not long after I bought it the plastic ring around the block that screws to the heat sink broke, leaving the block loose. The amp would shut off unless I wiggled the block. I tried gluing the plastic back together and it worked for a little while but it's doing it again. Does anyone have an idea what's wrong? I'm thinking the block needs to be replaced, but I'm not sure. Also, where would you recommend sending it to? I've already contacted Kicker and am awaiting their response, but if there is someone else you guys would recommend more (or if Kicker doesn't repair amps this old anymore) I will look into them. Thanks in advance. Quote Too many projects, too little time...
ISO Posted June 1, 2010 Report Posted June 1, 2010 I highly recommend useing Kicker for any repairs. I was skeptical about useing them until I talked to polecat and found out how reasonable the repair cost were. Go with Kicker and I doubt that you will regret it. Quote Isobaric - Refers to the practice of coupling two drivers together to make them act as one. "Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go." Insanity: doing the same thing over and over again and expecting different results. The Destruction of a person builds character.
ISO Posted June 1, 2010 Report Posted June 1, 2010 (edited) I think they will repair any of their amps. I sent them an original KX400.1 and they got it up and running and shipped back to me for $50.00. EDIT: plus a 90 day warranty Edited June 1, 2010 by ISO Quote Isobaric - Refers to the practice of coupling two drivers together to make them act as one. "Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go." Insanity: doing the same thing over and over again and expecting different results. The Destruction of a person builds character.
white4d96 Posted June 2, 2010 Author Report Posted June 2, 2010 (edited) Just got off the phone with them, they said it will typically cost between $40 and $90. So I guess I'll just save up some cash then send it in. Edited June 2, 2010 by ktownsdriftking Quote Too many projects, too little time...
Boon Posted June 3, 2010 Report Posted June 3, 2010 If you broke the plastic it's probably had a good shunt in the power terminal and the solder joint to the board is cracked (or the track coming off it, in some cases) Or it's shorting on something. Should be a pretty cheap fix. Does it still start working if you jiggle the connector? Quote 10.x volts fo' life!
