hi, i have an epic-160, a mmats 3500.1 amp and two mtx 9515''s in a 9 cubes box tuned to 35 hz !!...on the epic i never can reach more than 143 dbs....i have tested many tones...30- 50 hz and nothing....my car is a opel corsa...two doors...small cab think so....( like a pegeout 206 )
a friend of mine has an eclipse 2000, a orion hcca 5000 amp and a btl 15'' and he hits on epic 155 dbs !! whit music tracks....i used the same track than he and no more than 143....
do you think that the epic has a trouble or something...it is mountes righ under the HU.....or my sistem is not suposted to be that loud.....
let me know what you guys think....
hu ECLIPSE cd3100
FI BTL 18'' fully loaded 7ft3 @ 35hz with 126 sq
amp MMATS 3500.1
amp DLS ca23
set DLS up6
AUDIOCONTROL epic-160
KINETIK hc600
-monster cable-
the mic on the epic 160 is an ac mic so it might not be accurate
so what you think could be tha problem...or what can i do
hu ECLIPSE cd3100
amp MMATS 3500.1
amp DLS ca23
set DLS up6
KINETIK hc600
-monster cable-
i'd say sell the epic 160, get a audiocontrol 3.1 and get metered with some professionals. i thought about an epic-160 to see what i was hitting but heck nall, it's too much money for just that purpose.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
I have an epic-160 (I needed a bass processor, audiocontrol is generally good stuff), and I would not buy one again if I had a "do over". It is wildly innacurate. I have set up with a Term-lab metering as well to see how accurate. The epic will read different things every time. I even found a way to cheat the epic. Heat, causes mine to read higher. I had mine reading 159db while I was really only punching out a 150.1 on the TL. At first, the epic read 153, then I let the heater run. I did it again, still the same on the TL, but 155 on the epic. I moved all the way to 159. I only quit there because I didn't want to overstep its limits. I only still have mine because I haven't replaced it with something else yet. I have the "restoration" defeated. That "restoration" is the biggest pile of crap ever.
and you are correct, the epic 160 is boo boo as far as the meter thingy goes. i'd chose the 3.1 or 4.1 at that. i love my 3.1, crossover, eq and line driver all in one with master control and it's not complicated to play with either, MAAANNN!!
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
