Yeah that would be perfect... for those 2 sets of speakaz. Good luck!
for that amp it says it needs 4ga wire....im going to be running each channel at 4ohm, its rated at 60wrms @ 4ohm but knowing rockford itll put out a lil more. But would I really need 4ga wire couldnt I jus run 8ga, with that much power? And those 4x6's are 40wrms 80watts max ill be overpowering them quite a bit, jus watch the gains alot?
2007 Chevy HHR LT
UNDER CONSTRUCTION
1st Place Loud N Low 2010 MWSPL Finals
3rd Place Xtreme 3 2010 MWSPL Finals
I've got a 4 channel I can sell you for $100 shipped. It'll put out 85 watts, and if you use the high pass filter it's perfect for your speakers.
A couple links to some box builds:
Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI,
Mini-Bump, Hummer H2, Ford F-150
My own car builds (current setup --- under construction):
Overall Thread, Kickpods, Dash, Back Doors
Subwoofer Wall
bump...is 4ga really necessary for the output this amp is going to put it...will 8ga work fine? I mean 60x4 @4ohm only 240wrms 4ga doesnt seem necessary to me...
2007 Chevy HHR LT
UNDER CONSTRUCTION
  • Who's Online   0 Members, 0 Anonymous, 1472 Guests (See full list)
