ARMYSGT_D Posted June 3, 2010 Report Posted June 3, 2010 i have my big 3 done 1/0 then i have my run of 1/0 to the back going from my xs power d5100r to a 250 amp fuse up front to a 250 amp fuse at the back. then from the fuse to the d3400 and to 2 more fuses finally to the amps my amps. is this correct? do i not need 2 fuses between the battries any help would be appreciated current set-up kenwood ddx 712 clarion eq focal 165 k2p front focal 165v2 rear 2 re audio sexxx 12 us amps md3d us amps md42 1 optima yellow top (rear) 1 xs power 5100r (front) big 3 and 1 run 1/0 stinger wire my build my rebuild
hdorre Posted June 3, 2010 Report Posted June 3, 2010 I would recommend fuses between batteries. It seems good to me starter-fuse-fuse-bank-fuse-amp On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
spl4life Posted June 3, 2010 Report Posted June 3, 2010 2x sounds good... better to be safe then sorry... My first truck... My first Real build... *Update 8/9/10 DC Power 270xp Alt is In!!!* 1997 Toyota T-100 DC Level 5 18" in a T-line Everybody wants their system to be.... 1. Cheap 2. Reliable 3. Loud ...you can only pick two. micahmye hertz pack
ARMYSGT_D Posted June 3, 2010 Author Report Posted June 3, 2010 just wanted to make sure i had it right current set-up kenwood ddx 712 clarion eq focal 165 k2p front focal 165v2 rear 2 re audio sexxx 12 us amps md3d us amps md42 1 optima yellow top (rear) 1 xs power 5100r (front) big 3 and 1 run 1/0 stinger wire my build my rebuild
Freshman6969 Posted June 3, 2010 Report Posted June 3, 2010 I would recommend fuses between batteries. It seems good to me starter-fuse-fuse-bank-fuse-amp x2 Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k! Why would you EVER WANT flex?huh?...flex is what can make the lows lower and more air being pushed correct? My FeedbackJeep-BuildlogPT LOSER buildlog
