BTL FTW Posted June 6, 2010 Report Posted June 6, 2010 I've always run high power single sub setups so I've never had to work with multi sub ported enclosures. When I have run multiple subs it was back when I ran sealed and each sub had it's separate space. anyway I'm building a box for two fully loaded BTL 18s running a shared enclosure tuned to 33hz. In my new tahoe since they're sharing one enclosure do I just make it to double the recommended airspace for one or is there a special way to calculate? Alpine F1 Status DD CS6.5 x2 Front Stage DD 9512H DD M4a @ 2 ohm DD S2b @ 8 ohm per channel I run high ohn loads for MASSIVE headroom and cleaner SQ 270amp alt D2400 up front D3100 x2 batter in back
cubs_fan0718 Posted June 6, 2010 Report Posted June 6, 2010 14-15 cubes would work great. 06 Impala SSKenwood Excelon DDX593 Ampere Audio 150.4 Ampere Audio 5K1 XS D4700 (front)Mechman 320a Alt. w/ Big 3 Lots of Second Skin Damplifier Under Construction for 2017
BTL FTW Posted June 6, 2010 Author Report Posted June 6, 2010 so essentially double the recommended airspace for one? Only reason I'm confused is some systems seem to use less than that. Steves box looks small for 4 SMD18s. Each one of those likes about 8cf from what I understand Alpine F1 Status DD CS6.5 x2 Front Stage DD 9512H DD M4a @ 2 ohm DD S2b @ 8 ohm per channel I run high ohn loads for MASSIVE headroom and cleaner SQ 270amp alt D2400 up front D3100 x2 batter in back
fr34kout Posted June 6, 2010 Report Posted June 6, 2010 so essentially double the recommended airspace for one? Only reason I'm confused is some systems seem to use less than that. Steves box looks small for 4 SMD18s. Each one of those likes about 8cf from what I understand The air space on the SMD's is 4-7, less than that of the BTL's. You also have to remember though that he is giving them more power than the RMS rating so the smaller box is giving them more control with the higher power.
cubs_fan0718 Posted June 6, 2010 Report Posted June 6, 2010 yeah ur right on dude right around 14-15 would be awesome for those 2 subs. Subs up Port back. That box steve is running was for his btls, i think he said something about building a new box in the future. 06 Impala SSKenwood Excelon DDX593 Ampere Audio 150.4 Ampere Audio 5K1 XS D4700 (front)Mechman 320a Alt. w/ Big 3 Lots of Second Skin Damplifier Under Construction for 2017
fecupe2001 Posted June 6, 2010 Report Posted June 6, 2010 Yes he said it, i dunno why actually because that one sounds great and it´s a bit small, that way, he can give them that amount of power with less risk; I´m gonna build very soon a big box for my DD 3518´s , i wanted to get 11 c/f after displacement but i couldn´t buy the power i wanted, so, it would be 12 c/F, what power are you gonna use?? I´m the SPL Gains topic creator!! wanna get louder?? check this: SPL Gains. Panamenian 2009 & 2010 & 2014 Bass Race 149.9 Champion! 2 15" subs and a 2K wired at 1 ohm, http://www.stevemeadedesigns.com/board/topic/167788-fecupe2001-2-15s-on-a-2k-video-on-page-3/ 8 Massive 15" subs and small power, http://www.stevemeadedesigns.com/board/topic/179296-fecupe2001s-8-15s-4th-order-bandpass-wall/
blackrosetiger Posted June 6, 2010 Report Posted June 6, 2010 Yes he said it, i dunno why actually because that one sounds great and it´s a bit small, that way, he can give them that amount of power with less risk; I´m gonna build very soon a big box for my DD 3518´s , i wanted to get 11 c/f after displacement but i couldn´t buy the power i wanted, so, it would be 12 c/F, what power are you gonna use?? 12-15 volts lol had to say it 1998 Plymouth Voyager (daily) Jensen VM9213 H.U. (I Know but I havent had any problems.... yet) 5.25" Factory -> Sound Stream SST5.2 6x9 Hifonics ZXi 693 -> Sound Stream SST6.9 Amp: Class D: Crescendo 3KWP (x2) Class A/B: Crescendo 1000C4 Sub: Almani S-7 10" (x6)
fecupe2001 Posted June 6, 2010 Report Posted June 6, 2010 hahaha touche!!! What amps are you using?? I´m the SPL Gains topic creator!! wanna get louder?? check this: SPL Gains. Panamenian 2009 & 2010 & 2014 Bass Race 149.9 Champion! 2 15" subs and a 2K wired at 1 ohm, http://www.stevemeadedesigns.com/board/topic/167788-fecupe2001-2-15s-on-a-2k-video-on-page-3/ 8 Massive 15" subs and small power, http://www.stevemeadedesigns.com/board/topic/179296-fecupe2001s-8-15s-4th-order-bandpass-wall/
BTL FTW Posted June 6, 2010 Author Report Posted June 6, 2010 in my other car I'm feeding a loaded BTL with a rockford BD2500 and it takes it just fine Ifigured I'd run either one 4000bd per sub or two 2500bds per sub. My electrical can feed 8kw with 14-15 volts Alpine F1 Status DD CS6.5 x2 Front Stage DD 9512H DD M4a @ 2 ohm DD S2b @ 8 ohm per channel I run high ohn loads for MASSIVE headroom and cleaner SQ 270amp alt D2400 up front D3100 x2 batter in back
