ok i have a 4ch amp . how many speakers can i run off of that amp ? can i run 2 mid ranges per ch ? or will it kill the amp ? amp is rockford fosgate power t600.4 .. thanks for any help ...
alpine head unit (freebee 2009 model)2 sets of eclpise 5.25 comp. speakers.
1. set is in the a-pilors
1. memphis mojo 2500 watt amp
1. rockford fosgate t2 15"
dual 2 ohm wired to 4 ohm . seeing 600 watts
1. realm audio 600 watt 4ch
You could run 100 speakers per channel as long as the impedence is correct. You can run those two mid ranges to one channel if they're single 4 ohm speakers. If you wire them, you'll put 2 ohms on one channel
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
they are focal kp 165 4 ohm
u could run them on 1 channel, it will be as a 2 ohm load on that channel.. if u use 2 of them haha lol
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
2ohm is better right ? more power ? the focal can handle that ?
Amp says: 150W x 4 @ 2-Ohms RMS
Speakers are 4 ohm/ eighty watts rms each, so yes, you can hook up two of them to each channel to get 2 ohms. Make sure you give the amp enough ventilation, and watch your gains.
do i need the cross overs the speakers come with or can i hook up them up (tweeter and woofer) straight to the amp?
first off, how many speakers are u wanting to run in all?
u can run 8 4ohm speakers off that 4ch
i think mids n highs amps like lower ohm loads more than higher cause i had my hifonics zxi4406 runnin at 2ohm on all channels, had my front comp set and rear coax wired to front channels, and my 2 8'' dual 4ohm midbass's in back wired off rear channels and when i switched it to 4ohm on all channels it took a shit
so how many speakers are u wanting ot run?
and are u trying to run active or passave with external xovers?
if u want to run the speakers by them selfs off the 4ch u will been a external eq sorce to take the place of the cross overs the speakers came with, something like a rockford 360.2 or so
this lets u dial in to fine tune it a lil better
u can run tweets on front channel, mids on rear channel
4 tweets on front channels, 4 mids on rear channels
hope this makes sence, i need to get a good 4ch so i can run active, my headunit will let me run active but my 4ch is broke so im stuck running passave off a 2ch amp @2ohm
ok all together 8 sets of comps. on 2 fosgate power t600 4ch amps . they will go mostly in the stock loction and kick panels .. 61/2 inch front 51/4 rear .. that was my next question if i needed the external xovers . is it better to run active ?
  • Who's Online   0 Members, 0 Anonymous, 798 Guests (See full list)
