blcrocker Posted June 10, 2010 Report Posted June 10, 2010 So the other day I was taking a trip to the local grocery store and my amp shut off. I took it out and opened it up and was so clean I could see my reflection on the board like it just came out of the factory. So I looked around in it and didnt see any burnt up parts or melted legs so could it be that it just stopped working and died? I decided to put it back in, this time I had someone watching the lights on the amp and he said the red protect light turn on for a bit than went off. Anyone know what could be causing this? '01 Honda Accord EX 4 Cyl4/18/13 Started new build Headunit: JVC kdx250bt Sub Amp: Hifonics Hifi 2000d Door Amp: Rear Amp: Sub(s): SQ HDC3-12 Battery(s): Stock Wire: Knu 1/0 and 4awg Big3:
LoudNLow931 Posted June 10, 2010 Report Posted June 10, 2010 Short,bad ground,lose wire... 2008 Dodge Ram 2500 6.7l Cummins 4 FT1s C1600.2 8 PWX 8s ONX2.100 Audio Technix Wiring & Sound Deadener My Youtube Feedback
Guest Posted June 10, 2010 Report Posted June 10, 2010 my hifonics amp has the red protection light on for a while till it turns green if i remember correctly as a start up testing procedure...just saying, idk if your amp is like that. but x2 what loudnlow said.
ISO Posted June 10, 2010 Report Posted June 10, 2010 Thermal protection. End thread. Isobaric - Refers to the practice of coupling two drivers together to make them act as one. "Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go." Insanity: doing the same thing over and over again and expecting different results. The Destruction of a person builds character.
steven Posted June 10, 2010 Report Posted June 10, 2010 I had this happen twice once was my ground was bad and the other my remote was bad. Did the exact same thing as you described.
BeachJoshua Posted June 10, 2010 Report Posted June 10, 2010 Make sure you don't have any exposed wire... if anythings exposed put electrical tape around it, this has cause a good bit of problems for me. | S-10 | 4.5^3 ft | 33Hz | SAE-1000D @ 1 Ohm | 2 SA-12s | SPL: 143.7 Sealed | 153.4 Port Wars
Cashdollar2009 Posted June 10, 2010 Report Posted June 10, 2010 A bad ground will definitely cause this. Check your rear ground and make sure it is nice and tight. My friend from school was complaining about the same thing... He ran a screw through the steel for a ground and a thread popped back out and it was loose as shit... On 6/30/2011 at 1:11 AM, 'Ray' said: Acoustical energy is free. Electrical energy is not.
blcrocker Posted June 11, 2010 Author Report Posted June 11, 2010 I've never been real sure on if my ground is good or not. Its on nice shiny sanded down metal but I think recently there has been some corrosion around it so when my new wire arrives tomorrow I'm gonna try a different spot and see whats up. '01 Honda Accord EX 4 Cyl4/18/13 Started new build Headunit: JVC kdx250bt Sub Amp: Hifonics Hifi 2000d Door Amp: Rear Amp: Sub(s): SQ HDC3-12 Battery(s): Stock Wire: Knu 1/0 and 4awg Big3:
