Amp Problem..
evermaxx
Okay well this isnt for my setup, but a friend is on a budget build and well he has 2 Kicker Comps - and a 1600watt BOSS Amp.. The thing is its behind his seat on his Grand Cherroke between the box and the back seat.. And it gets pretty damn hot.. We were sitting there listen to it since he just hooked it up withen about 10mins the protection light comes on, not sure because it was drawing up much power to the speakers, or if it got to hot. Thing I am asking is ways to get it from heating up so hot?
and for the lazy people who dont like to read :D
Cliffs:
Boss 1600watt amp
Really hot after 10/15mins of use
Mounted on the ground between back seat and sub box.
How can it be cooler?
Edited by evermaxx
Team Subsonic Lows
Get your garbage EMF products of my amp bitch
Man....it makes a nice work bench ;)
What coils are the subs? Specs on the amp? it's probably because its on the cheaper side of amps. make sure his grounds are all good, and the amp isnt seeing a lower impedance that it should be
Team DC Audio : Team Shok : Team NWSPL Co-Founder
Head: Pioneer AVH-P5200DVD
Front Stage: Morel Tempo 6.5's/ CDT 6.5's
Subs: (4) 15'' DC XL's, 15 cubes @ 38hz
Sub Amps: (2) Shok 5k's
Speaker Amp: Shok 100.4
Wiring: Shok Industries 1/0
Electrical: White Mechman 270/Adjustable Voltage/3 Shuriken BT120's/3 XS XP3000's
FPiYT.jpg?9395
2 DVC 4ohm
1600.2 (They are bridged at one tho)
Team Subsonic Lows
2 DVC 4ohm
Wire the subs to 4 ohms. This will take care of the thermal problem. You will lose a couple of db's. Won't notice. People who say they run at 1 ohm or 1/2 ohm or 1/4 ohm, daily, are full of shit. Maybe for a few minutes. Some amps will do this but they will burn your hands (like my old school 2100 hcca and 225 hcca would do), and cheap amps will burn up if you continue to do it. My power series rockfords will shut off after 10 minutes or so at .9 ohms. I usually listen to my music the whole time im in the car and that might be a little more than 10 minutes. I run my subs at 1.8 ohms. One sub on one amp.
im not trying to be a dick but if ur gonna buy cheap shit then ur gonna have those problems but just spend more money and buy a good quality amp
Introduce a no fat chicks in the whip rule.
Im gonna have tech force make up a sign that says that and put it on my car lol
Okay.. well how would you wire those then?
[/quote
On subs positive to negative negative to positive and then to the pos to pos and neg to neg then into amp. I think that will double then half. Use a DMM. Your subs probably aren't at 4 ohms. Maybe more maybe less. Mine go 3.8 per coil, to 1.8 series to .9 paralel(sp) It doesn't take much of a ohm resistance to make a difference. The lower the ohms the closer you are getting to a dead short. Check each coil. Run a wire to the other coil from the (+) to (+) and negative to negative. Then take the wire to the (+) on the first coil to the negative on the second coil, and the negative to positive. See what that reads. Amps will run all day at 1.3 up. That's why JL puts there subs there. When you see the numbers on the DMM set for ohm's you will know what I'm talking about. The electricity doesn't care how you wire the coils they will get the same load. It's summed on the entire load.
Yeah I hear ya man this is just temp shit belive me.. I have planned 2 18" RE Audio or 2 18" DC Audio LVL 4
Team Subsonic Lows
good but to solve ur problem for now put a pc fan ontop of it or have some sorta fan on it so it will cool down
  • Who's Online   0 Members, 0 Anonymous, 1629 Guests (See full list)
